I'm new to the forum and have a question that a few hours of searching the archives hasn't been able to answer.
With any luck, I'll be getting close to putting a new roof and slab in an existing pole barn this summer. I'm settled on the choices for those two things, but need to decide what to do for insulation in the walls. I know that condensation is a concern with pole barn insulation and I also know that spray foam is a solution. That said, spray foam isn't in the budget.
I was researching solutions and found this for a retrofit solution: http://www.insulationstop.com/post-frame-pole-barn-retrofit-wall
Obviously that's not enough insulation here in Michigan, but would an acceptable solution be to use the double bubble foil over the purlins, taped and sealed, with a layer of fiberglass bats (vapor barrier or not?) and then finished to the interior with OSB, plywood or sheetrock? Seems that the foil should combat the condensation issue, but I know that vapor barrier on the cold side is opposite of standard practice in a cold climate like mine.
I'm still a few months away from having to decide, but figured someone here might have an answer.
Thanks in advance!
Rick
Thanks in advance!
Rick
