I have a 25 x 35 pole barn I will be rehabbing. currently I have shingles, but the previous owner had no ventilation and the shingles are kinda shot. I will be putting a metal roof in its place. I want to remove the shingles. and lay the roof over the plywood. I will need to repair some of the wood. what is the best recourse of action for condensation and insulation. I will insulate the entire thing in the future and may go as far as HVAC, but that is TBD as of right now. I would rather prepare through for the start.
I have read:
ply
roof felt
slip sheet
metal roof
no furring strips?
this will only help with condensation and keeping the roof dry correct? no insulation? so do i insulate from the inside? Inside are common trusses 2' OC. would i just use rolls between them? put up foam board or ?? if I have a ridge vent for the metal roof how does ot breath if I insulate the entire ceiling? pictures i see online and things I read the entire inside is buttoned up. I was always under the impression you need to have air flow. what am i missing.
I have read:
ply
roof felt
slip sheet
metal roof
no furring strips?
