Pole barn Interior Walls
89pigeontoe
I have a 34×40 Pole barn with 14 foot walls I am looking to frame up and insulate. On the walls I am going to put up plywood 8 foot up the wall and then white metal the rest of the way and eventually install drop ceiling with white metal. My question is since I will only be using the plywood portion to do any mounting to the wall can I only stud up that 8 foot portion on 24 inch centers and for the top half just use enough stud to hold insulation and screw the interior metal too and be ok?
callcoy
Nashville
I had a little larger pole barn w 14' walls built and have been doing all the finish work myself, electrical, plumbing,interior and insulation, but not the concrete work. Just had 5000+ sq.ft. poured and finished between the driveway and shop.
I decided that I would panel the ceiling and walls with the same siding we used outside and had to come up with some thing to fasten to and hold my insulation. I was able to locate up in the Mennonite area a little north of me, an individual that has a working saw mill. I spec'd out 1" net x 6" net both southern pine and tulip popular, placed this horizontally on 23" centers, insulation is only 23" wide and stapled it every 2 courses.
On the ceiling I placed the "Battens" on 24" perpendicular to the trusses that are are on 48" centers and laid insulation (R-38) across the battens. No real sagging but when completed the metal siding will support what might be below the battens.
Now to kind of answer what you had posted, with the battens providing the attachment and backing of the metal siding, I could run 14' long pieces vertically and use spacing to attach cabinets and etc, to,. but I will use sheet rock and plywood to the battens for those areas I know where a flat surface would work best. I plan on just butting my siding to the rock or ply, may use a J trim or some kind of edge molding to finish it off.
Uncle Phil
I have 14' ceilings and I am in the process of doing what you described. Above the metal I'm just going to split the difference and add 1 additional cross stud , I guess you might call that a girt, between the top of the plywood and the ceiling. Honestly, it probably doesn't even need that if it is screwed at the top and bottom. However, it will provide something to help hold up the insulation.
Uncle Phil
Here is a pic before the plywood. When I put up the studs I cut spacer blocks and screwed those to the building posts. I am usually working alone so this way I didn't have to measure or hold the other end of the 2 x 4 x 16. I had two different heights of blocks to make the spacing come out right. After I screwed the stud on I moved the spacer blocks up and repeated.
NUTTSGT
Northern Central Ohio
What are you insulating with ?
NUTTSGT
More than likely 24 inch wide rolls 8 foot long. I haven't purchased anything yet but that seemed to be about the easiest without breaking the bank.
If you are using kraft faced insulation, them I would think you need the stud wall to attach it to.
Take your time and do it right. You'll be kicking yourself in the **** if it's half assed and you need to redo it in the future.
Does 24" OC come in a single roll like 16"OC insulation does ? I generally buy the single roll and cut it to length myself.
GRivera
20 mins south of Baltimore
Looks great- what insulation is that?
Redraptor
Greenville, PA
I bought a property next to mine that had an older 24x32 pole type 2 car garage that had an OSB type of siding that was getting rotten at the bottom. While replacing the pieces for a backer for vinyl I discovered that the 24" insulation was put in horizontally on perloins. The interior has OSB walls and ceiling so I had no clue.
Hubmonkey
OK
12' walls in my 24x36.. I did 16"OC stud walls and roll insulation then drywall.
Hub
Uncle Phil
2" of closed cell foam. What you don't see is the un-faced R-19 behind the sheeting. The attic will be blown in cellulose.
