Folks,
I've received estimates and had the county engineers design the plan for power to the Pole Barn. County estimated that I would need 100 amp service from an existing power pole. Will be an aerial connection of about 75 feet.
Local Electrician said I would be better off with 200 amp service from the same aerial pole.
The 30 X 36 X 12 pole barn is for auto restoration and general hobby work. I would like ample power with room to grow if needed. Here is what I plan to run.
1. A least 15 overhead t8 fluorescent lights.
2. A 33 gallon air compressor, later a stanionary 60+ gallon compressors.
3. Lincoln MIG welder, with future TIG Welder
4. Full size blast cabnit with dust collector.
5. Ceiling fans X 4
6. Future 2 post lift.
7. Approx 16 110 outlets and 2 240 outlets. Drill press, bench grinder etc.
8. Outside security lights.
9. No heat needed in Florida, but future Split system AC unit. Not sure of size since it will be several years before I can afford or consider AC to the barn.
Future plans beyond what is listed may be an attached paint booth, covered lighted car port. Possibly a 12 X 24 workshop branched off the barn.
Thanks for the help.
5. Ceiling fans X 4
