Pole barn radiant heat
the bus driver
I am planning on building a pole barn, it will be broken up by ware house area and heated work space are. Will this cause any problems having only part of a slab with radiant heat in it?
Weedwaka
Shouldnt cause any problems but if its a single one piece slab, I would install a thermal break between the heated and non heated areas. Otherwise, you will be heating the whole thing.
