Pole barn shop ideas
Kangaroo ID
N. Idaho
So here is my question. I have been planning a shop for my property, it will be a pole type construction 40x60. I want to build it with three garage doors on the sides instead of having them on the gable ends. The building will be used for parking a few extra cars and my tractor but also used for a work shop. So i wanted to hear if any one had thoughts on advantages of doors on the sides vs. on the ends like most if the buildings i see in my area? I just joined the forum the other day and have enjoyed reading all the ideas and projects.
3pedal
Brighton, CO
Mine has the doors on the side. It works well for me. I think it does limit height of the doors a little and of course, you can't put as long a vehicle in it. A lot will depend on the layout of your land and where your driveways are.
Bear
Salem, Oregon
If your building a pole bldg. it won't cost much more to have 16' walls rather than 12'. That gives me 14' doors on the side and a 20x40 loft area in my 40x48.
tomroblee
Indiapolis, IN
The side walls are the load bearing walls. It takes heavier lumber to frame a garage door size opening in a load bearing wall.
One major factor depends on whether you are in a heavy snow area and are planning to have a metal roof. Snow will slide off a metal roof. When it does, you don't want to create a snow pile in front of a garage door.
tn89
east TN
I'm building a 45x100 right now and I am putting 3 12x14 doors down the 100 side and one 16x14 on one gable end. Me personally I like the doors on the long side
finn
The UP, God's country
Don't put the doors on the eave wall if you live in snow country. The snow slides off the metal roof and compacts when it hits the ground. A snowblower won't remove the compacted snow, and even a truck mounted blade leaves a hump.
Gable end doors rule!
shelbyz28
Central Iowa
I went with sidewall doors due to my current building and driveway layout. I like being able to access 4 bays at any time and not block in projects. I have other old farm buildings that are long and narrow and if I have 2-3 projects going at once, something is always in the wrong spot.
My bigger snow issue so far is drifting; my 4/12 pitch doesn't send a ton of snow to the ground in massive amounts, but I'm also only on winter #2. I have an identical snow pile infront of a neighboring building rotated 90 degrees (gable end doors), so while in theory it works out, I'm not finding a large practical difference so far. It may also make a difference what direction your building and doors face relative to the sun.
