Pole Barn Spray Foam and Venting....
kbeefy
Harington, Eastern Washington
I have a 32x36 Pole Barn. Eves are about 14' high.
Walls are 2x4 framed, fiberglass batting and OSB interior siding. Metal outside.
I need to do something to the ceiling.
I can see no roof venting. It wasn't insulated or heated as built.
I am torn between installing a ceiling w/ blown in insulation, and some roof and eve vents or just having spray in insulation applied.
I am in central Oregon, we occasionally see 100 in the summer and 0 in the winter. Niether extreme lasts that long, and it doesn't rain much but our snow load can be significant at times, but doesn't last more than 4-6 weeks.
This shop will only be used for weekend projects 50-60 in the winter and maybe AC for the summer. With added roof insulation temps might be manageable in the summer.
Heat will probably be from a Big Maxx 80k propane heater
yeldogt
Have you checked around for advise or prices -- ?
Nothing works like closed cell foam against a roof deck for heat gain .... I'm using it in my current project under a huge roof -- cathedral ceiling.
Mine is more typical construction .... pole buildings are treated differently depending on type.
dcg9381
Austin, TX
Foam for sure. Just the ease of installation and time to install - seems like a no-brainer to me.
Are the eves vented at all? Typical foam buildings are not vented, but non-foam buildings are and it sounds like you don't have a ridge vent.
Add a mini-split (or two) and you'll be fine..
