lakeroadster
Mine is a hybrid post frame/stick built. I started off putting up a post frame pavilion. Then I poured the concrete slab. Then I put in 2x6 PT sill plates in between the posts on the concrete.
Where do you live Earl? Someplace where the climate is warm?
Everything I have read recommends against this^^^. And in my life I have seen slabs heave during winter months.
Let me explain further...
On a pole building there is no foundation. Therefore the slab you pour (above the frost line) floats and moves with the movement of the soil. The posts (That are installed below the frost line) do not move.
This means there is relative movement between the posts and the slab.
By placing the sill plate on the slab, and attaching the walls to the sill plate and to the posts, there is now a battle between the slab movement and the poles.
Of course if you live in a warm climate where freezing isn't a concern, then the above is not an issue..... unless the sub-grade compaction was done improperly... and the slab settles.
