pole building ceiling insulation
wantacoe
Sycamore, il
I was using foam sheets in my ceiling but it is turning out to be way to much work. Nothing is straight, square. Some of the rafters are 3 inch difference in a 8' run. They are not straight up and down. So, What is an easier way of doing this other then spray foam? I don't think they could get up there to do that.
W
wantacoe
Sycamore, il
Trying to insulate the ceiling. No two rafters are set at the same distance. Most are 52 to 61" on center.
u2slow
BC
I would probably strap the ceiling at a better spacing. Then you could do batts, or boards... or both.
ace10
Rural NoVA
Is the framing the bottom chord of trusses or actual ceiling joists?
If they're the latter, you could just reposition them to correct the spacing.
If the former, and you can stand to lose a few inches of headroom, then just run perpendicular straps for rigid insulation or 2Xs on edge for batts.
