I need some advice on running the electric on my pole building (garage). Conduit has been used for most of the runs but I need considerably more outlets and lights. I want to continue to use conduit but I'm not sure how to make the runs so I can insulate the garage as well. If you look at the attached picture, you can see the way the conduit has previously been run. Will I be able to insulate and cover the walls or will the conduit have to be hidden inside the wall at the ceiling/wall junction? How do I attach drywall (or whatever is used) to the walls? I would assume I have to add 2x4s in the wall to support the drywall but I'm not sure how to do this. My plan is to run the electric and have it inspected and final connections made by a professional. Then I will probably use batts of insulation and drywall or OSB. Any help is appreciated.
