Pole Building Insulation Question
PapaRiley
Hello Everyone! I am new to this form so i apologize if I am asking a question that has been answered on here before but I tried searching and couldn't find the answer I was looking for. I am currently having a 36x24x15 pole building being built in Cle Elum, WA area. I have an 80,000 BTU heater I plan to put in and also plan to insulate. I have an idea for the walls but not sure on the ceiling. There is no roof overhang therefore no soffit vents to allow an attic with a ceiling and blown in insulation (which I know is the correct way to do it). Spray foam is out of the question too. I was planning on putting up fiberglass insulation between the roof purlins which will be 24" OC. I have read however that this is not ideal because it will cause condensation issues. Is there another way to do this or something to cause if from condensating?
Thanks,
Riley
P
PapaRiley
Plan on putting a propane heater, something like a Mr. Heater 80k unit. I’m thinking when gone would keep it at 55 or something so it doesn’t get super cold in there.
bullnerd
Jersey
80,000 sounds high? Did you calculate this or is it a guess?
I have no advice on heating a space without soffit and ridge vents, I don't know enough about the subject.
Good luck, heat is good!
Radix2
the thumb!, MI
You don't have to use soffit vents to vent an attic.
If no soffits, then you can use gable vents. ( like the millions of homes before soffit vents got popular)
I would blow in cellulose in the ceiling since it is simpler, does a better job and is inexpensive.
P
PapaRiley
I just guessed on the 80,000. Figured better to go bigger than not big enough.
I always assumed attics had to have low point and a high point for air circulation, didn’t know gables and ridge vent would work.
Let’s assume I still decide not to go with a ceiling because I want the trusses for storage even though I know I would have to sacrifice insulation to do this. Have any suggestions on a good way to insulate?
Captain Spaulding
Southern Indiana
If you have exposed metal roofing on the inside, any warm air that contacts the metal will lead to condensation. If you have a ceiling below, that can cause rain onto the ceiling which isn't good. Same way with insulation bats. The answer is a vapor barrier someplace in the mix to completely isolate the air inside the shop from the roofing metal.
Figure up the cost of a (ceiling) + insulation + vapor barrier + (vents) and the effort to install it before dismissing spray foam since it would be a one step solution.
dmulally
I am insulating my pole shed at the moment. I unscrewed all the roof sheets (9 meters long) and slid builders/roofing paper above the joists and below the sheets. Was a slow process but now I have a barrier between the metal roof and the insulation.
P
PapaRiley
Thanks Captain Spaulding. That makes sense if I put up Vapor Barrier that would help. Your right too I should probably at least get a quote on spray foam before I say it is to expensive.
dmulally - that sounds like an interesting idea. Are you insulating between the roof purlins then too?
Jake40
Green Springs, Ohio
If your gonna insulate between the roof joists make sure you stuff the cavity tight with insulation. You don’t need ventilation if the cavity is packed tight. If you use a faced insulation you don’t need to put up any plastic because the paper is a vapor barrier. This isn’t 1970 anymore plastic is bad.
