My metal pole building has 3" insulation installed (roof and walls) and it doesn't work as well as I would like and I want to help it out some more if I can. I am ready to begin adding some inside walls and was thinking about adding either bubble foil, reflectix breathable foil wrap or similar as a radiant barrier. I realize this wont do much for R value but I am thinking it might help with radiant heat. I do not have central heat/air but I do like to heat it up in the winter time but only when I am out there using it. I considered adding more batt insulation but the cost is much higher obviously.
What have you done and how did it work out?
