Pole Pig Transformers
Norcal
Just a FYI 480 volts is low voltage, as is anything 600 volts & less.
Steve from Socal
Hutchinson Ks.
Norcal,
My use of the term "low voltage" was in regard to the 480/240v. I am aware that 600 VAC and under is classified as low voltage. With small machine tools "high/low voltage" with respect to their overloads etc is often used. My little shop here is all small machines and tools, 75HP and under.
Steve
madosta
Today I learned what the inside of a transformer looks like. Thanks! We need a wiki of cool electrical stuff!!!
What I ended up doing is, continue using the transformers for the time being. I have a 75KVA dry transformer that I got a few months ago, it is on the long list of things to do! These are on the metered side of my 480 service, they are 480-240v. My low voltage service; 240 delta and 240/120 is powered through these transformers. They are not on the pole, my main 480v panel supplies these.
Steve
With dry type x-formers you dont want to load them more than about 80%. Not sure what load you will be putting on it, but I wouldnt put more than about 150a continuous. IIRCC, the oil cooled x-formers are 300kva total so you would loose a LOT of capacity changing them out!!
Just the reason why i said high voltage line side metering, such as 12kv!
Steve from Socal
Hutchinson Ks.
The lighting and receptacle plan is still in flux, If I can find some 300VAC Edison bases I can use 277v CFL's My future plan is to split the 240/120 service into two feeds, one the small dry transformer and the other the current transformers.
I have about 45K sq ft and am a one man shop, my largest loads are my 60HP compressor and my 25HP mill and lathe. The only things I have wired 240 are a couple of 1HP chain hoists, my water heater and, my 5HP air compressor. I have a 15HP mill that was 240, it is being changed to 480. My lighting load is 28-105w CFLs, 46-55w CFL's and a couple dozen 4 and 8 foot strip fixtures. I am slowly relamping the strip fixtures with LED's.
Being a one man show I don't run everything at once and my shop is divided into areas, a machine tool room, sand blast and paint, welding and fab, mechanical and repair, warehousing, parking, precision grinding and office. Even with all these areas lit, electronics and appliances I have no more than 25% load on the dry transformer. The lighting load will increase over time and a fridge, washer/dryer etc but, still nowhere near the limits of capacity in the short term.
If my products are successful I would gladly turn the big transformers on if needed of course, I just don't see the need to pay a greedy utility a hefty demand charge just to keep them warm.
Steve
zkling
I have nothing useful to add, sorry. I just wanted to say, they make one hell of a Jacobs ladder. :evil:
zkling
Jacobs ladders are done with x-formers that have kv rated primaries. The OPs x-formers are only 480v on the high side!
:headscrat I thought we were talking about the standard step down, power pole distribution transformer? :dunno:
Edit, never mind. That is what I get for not reading page two. :eek: Off to go try to pull my foot out of my mouth....again.
