Hey thanks. The batteries are dead. I put the multimeter on 200m and I can get just a 1 to show up as I run across the 4 blades. So I guess the question is here, I don't know that I know what to test when the battery is dead?
Hopefully that was the 200m
V range boilermanc. If so then 1mV is very dead indeed.
Without having one to look at I can only guess, but there's two possibilities that I think are likely.
Possibility 1.
With most Nicad stuff any extra battery terminals are normally only used by the charger, not by the tool itself. So if you look carefully at where the battery contacts to the tool, you may find that only two of those four contacts are used. Those would the two main poles.
Possibility 2.
If all 4 contacts really do connect to the tool then it's possible that DeWalt have decided to split the 24 volt pack into two banks of 12 volts each. There are some definite advantages in doing this.
To see if this is the case, can you try measuring the voltage between pins 1 and 2, also between pins 2 and 3, and finally between pins 3 and 4 of the pack (just number the pins left to right for reference). Make sure you use a voltage range on your multimeter.
BTW. Can you try the charge the battery even a little bit before testing? Or does the charger just totally reject it and refuse to do anything at all?
