polishing a #80 ag chain
bouldermsm
Hi Folks,
I'm just wrapping up a **** project for some friends who completed Ironman Wisconsin a few weeks ago. I am trying to put just a little polish or shine to the outer plates and out facing pins of this State of WI chain-frame. I've tried a flap wheel sander and a stripping wheel on the grinder without much luck, the surface is just to uneven and chews up the wheels. If I polished the outside of the inner link as well that would be fine. Maybe a reasonable solution doesn't exist for what it is.
Any suggestions appreciated.
Dave.
astroracer
Mid_Michigan
A rock tumbler with polishing medium would work well.
Spray the chain with clear laquer to keep it from rusting.
(unless it is already in the shape of the state...)
Mark
bouldermsm
Thanks for the idea Mark. Can't say I've used a rock tumbler before but I should have mentioned that I am just wrapping up this project and it's rigid welded/painted as pictured above if that makes a difference.
Dave.
zkling
Semi loose buffing wheel and start with a very coarse compound. Followed by a wheel heavily coated in mothers mag and aluminum polish. You should be able to use it as a mirror after that.
Tip is to run the wheel along the length of the chain, not across, or it will want to grab and round over the edges.
bouldermsm
zkling,
Thanks, I would have never thought of that. I don't own a dedicated buffer/polisher but have all sorts of fixed/variable speed drills and 4"/7" grinders. What is the typical rpm for each of your suggested steps? I guess I need to be able to chuck-in or thread on the wheel, too.
Dave.
zkling
zkling,
Dave.
Do you have a 6" bench grinder? You can put a wheel on a angle grinder, but you need to be very careful as the RPM is ~3x what you want it to be.
bouldermsm
It's funny that I can't seem to think of any of these when it's something I've never tried!
Yes, I do have a fixed speed bench grinder. The piece is 30 lbs and awkwardly shaped so it might be a challenge presenting it to the bench grinder as opposed to vice-versa with a angle grinder while it's laying flat on a bench.
I'll stop by the stores today and look at the recommended RPM's for the wheels and go from there. I have an extra few links of chain I can practice with.
thanks again.
Dave.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Other than chrome plating, I would leave it like it is, and just spray it with some clear. No matter what you do, you won't get the results that I believe you are looking for unless it's chromed. The only other alternative is to spray it with a silver paint, or spray it with some sort of a color that goes with the scheme of things already.
bouldermsm
I've had some good luck thanks to the forum's input. I was definitely in the "trial and error" phase and found some great suggestions outside of my diminutive mental box.
I've got the links looking better and will rattle-can some clear on it tomorrow and post some more photos to close the thread.
Thanks again. Dave.
