Poll for Nastyzen's dimple dies
Which type dimple die set do you want?
  • Total voters
    62
Jim Stabe
San Diego, Ca
Who wants which type:
Standard size set to use with standard hole punches/hole saws
Pipe size set to use with pipe size punches
When you vote add a post so Claude can contact you about payment and delivery
NASTYZEN
St-Colomban,Que. Canada
standard for me. Where can we see these dimple die sets ? I sure do like pictures, hint hint.
Here you go.
This one is the first of a total of 6 to come.
It is a 1.0''
You can follow the build here.
http://www.garagejournal.com/forum/showthread.php?t=38532&page=7
tpierce
I would like the pipe size. Thank you for doing this! I just need payment info.
juiced10
Parish,NY
I am interested in 2 sets of the pipe size but will take standard sets if that is all that is available. It is way easier using knockout punch sets for the holes. Thank you.
StumpXJ
Decatur, Georgia
****... can I switch mine from standard set to a pipe set??? I am just now realizing how easy the knockout set would be to make a bunch of holes... Sure beats a hole saw.
Let me know if there is anyway I can change over.
~ Stump
NASTYZEN
~ Stump
This poll was only to determine aprox. how many of each kind I should make for the first batch.
I have materials for about 40 complete sets.
I am making 30 of the regular size kits which consists of 1/2 , 3/4 , 1.0 ,1 1/4 , 1 1/2 and 1 3/4 sizes.
I am leaving 10 sets aside for the pipe sized dimple dies of which I have yet to determine what exact sizes they will be, once Jim punches out actual holes and physically measures them when he comes back from his holiday in a week or so....
But first I am going to complete the kits of regular sizes.
Then I will make the pipe sizes.
If there is interest, I am going to make other sizes.
Then....If there is still interest from more of you guys for these , I shall make a SECOND batch. I just don't want to be stuck with a whole lot of these in my shop..........
As I have mentioned before, I am aiming to have them available for sale at about $120.00 CDN for a set of 6 reg. sized dimple dies. This may change a little if the larger sizes take more time to make than what I have done with the 1.0'' ones so far. The material costs also go up the larger the dia.
These will be sold from my friends web site. Of which I shall post up his link, once I have complete kits available.
You will pay him via whatever. ie credit card or cheque or whatever he deals with, for a small fee.
The shipping shall be via Canada Post and you shall pre pay for the shipping in the same transaction.
At this point my friend shall e mail me ( Your ) address and all I have to deal with will be to box the kit and mail it to your doorstep.
Sounds simple.....I hope it shall be.
I hope this is clear enough for all of you.....
I am trying to be on this full time to make everyone happy, please bear with me as I am a one man factory juggling many projects at once, snowblowing the yard and having to deal with lawyers.:eyecrazy:
As I make progress, I am posting it all on the Dimple Die thread in the fab section.
Thank's
Claude
:beer:
gc427
Glendale, AZ
I would like a pipe size set.
Thank you NASTYZEN for all of the work that you have put into this project!
NASTYZEN
Thank you. Yes it is a lot of work.....:)
whats the difference between the types of sets? noob to dimple's but could use a set
Regular size, ie. say one inch, the hole needed is actually 1.0''.
Pipe is measured from the inside. ie. 1.0'' pipe, depending on the schedule, is larger. 1 inch sch. 40 pipe is about a 1.180'' hole.
The purpose of a pipe sized dimple die is to be able to be compatible with a HF or other pipe hole Knock out punch set.
So far, done with the 1.0'' and 1.25'' sized Dimple Dies with 10 sets of blanks of each, set aside for when I get dimensions from Jim for the pipe sized ones.
All materials cut down to size.Just machining left to do. Lots n lots of it.:)
Boost Creep
michigan
thanks for the info. i'm down for the pipe size and if you make a second batch later probably a standard set just cause :)
sarel.wagner
Centurion, Gateng Province, South Africa
NASTYZEN, my Pipe set with the following specs:
The Dies are 33.5mm heigh (1.32")
Die 22mm = Hole 21.8mm (0.860") Through hole
Die 27mm = Hole 26.8mm (1.055") Through hole
Die 34mm = Hole 33.8mm (1.330") Threaded
Die 43mm = Hole 42.8mm (1.685") Threaded
Die 49mm = Hole 48.8mm (1.922") Threaded
Die 60mm = Hole 59.8mm (2.354") Threaded
Big mandrel
Over All Length: 77.5mm shaft 19.95mm with Thread both ends 20mm*1.5mm pitch, Unthreaded shaft length 40mm
Small mandrel
OAL 86mm shaft 11.0mm with Thread 10mm*1.0mm pitch, Unthreaded shaft length 50mm
Hope the above is clear :)
Rgrds
