gogolf0401
So I know this topic has been discussed a few times on here already... but I haven't seen a overwhelming straight answer.
I have a 40x88 pole barn that will be heated to 40 or so (radiant floor) and then bumped up to 60+ when I'm working in there via forced air heater. I already have the walls spray foamed with 2.5" closed cell which is about R16-17. I have will have steel liner on the ceiling and walls. I am planning on cellulose or fiberglass blown in the ceiling. I am wondering if it is necessary to have poly vapor barrier on the ceiling under the steel.
I live in MN where it is common to have several days below -20 or -30 degrees Fahrenheit during winter.
I have heard it both ways:
1. No vapor barrier... you need to let the moisture escape somewhere and it won't be the walls since you have spray foam. If you poly the ceiling you will end up with condensation on the steel.
2. Yes vapor barrier... you want to keep air movement to a minimum and keep moisture from getting into the ceiling insulation.
What have you guys done, what are your results and what do you recommend?
Thanks!
Thanks!
