arichardtx
Found an Installer that I am almost ready to go with for my garage flooring project (~800 sft) and I feel really good about the following
1.100+ reviews on HomeAdvisor 4.95 rating
2. good price
3. lifetime warranty
4. good impression of Company (google)
5. good impression of Installer and franchise owner of "Company" (exchange of email and onsite visit): knowledgeable and ethical
The final open question/concern I have is the materials being used and I am hoping to get some guidance from this forum. Specifically I am looking for
1. Has anyone heard of American Industrial?
2. Has anyone heard of American Industrial 70% Solids Polyaspartic called TC One?
3. Has anyone used TC One?
4. What are the most important specifications (priority order) I should I be concerned with when looking at or comparing Technical Data Sheets?
Adhesion ASTM- D4541(psi)
Abrasion Resistance ASTM-D4060 (mg loss)
Wear Resistance ASTM-D968 (litres sand/mil)
Impact Resistance ASTM-D2794 (in lbs)
Flexibility ASTM-D522 (fails or passes)
Color & Gloss Retention ASTM-D4587 (Level 1, Level 2, Level 3)
Tensile Strength ASTM D412
Elongation ASTM D412
Compressive Strength ASTM D695
Tear Strength (PLI) ASTM D1737
Others??
Details of Product/Materials and Process
Product/Material: Primary material is an American Industrial 70% Polyaspartic called TC One
PROCESS
0 PREP
diamond grind
repair small cracks Polyaspartic mixed with Cabasil (fiberglass)
diamond grind repaired areas
1 [first coat] pigmented base coat using American Industrial TC One
2 [second coat] pigmented second broadcast bed coat using TC One
2 [second coat] American Industrial Terra Chips vinyl-acrylic paint chips (full broadcast)
3 [third coat] clear top coat using American Industrial TC One
Result: Typical thickness for finished system is 16-20 mils
American Industrial Technical Data and Application Data
aiflooring.com/Data.html#header3-2
TC One Technical Data
aiflooring.com/TDS/TCOne_TDS.pdf
TC One Application Data
aiflooring.com/Application/TCOneApplicationInstructions.pdf
Thank-you in advance for any advice and guidance!
2. good price
Others??
PROCESS
0 PREP
diamond grind
