Hi all - I've read a few threads about problems with polyaspartic floor coatings and wanted to ask for advice about our home. We had 100 SF of polyaspartic coating applied in our basement in early April. The application was a two day process with a base coat applied on Day 1 and the polyaspartic top coat applied on Day 2. Both coatings were applied on days where the temperature was in the 70s during the day and probably the 40s at night. We are in Colorado so the climate is dry.
We have an air quality monitor on the first floor of our home. Since the installation occurred, the VOC levels have been extremely high. We have had a few cold snaps with snow or rain (7-10 days after the installation occurred). The VOC levels have spiked when the it has been more humid outside or when we have needed to use the furnace. It has left me feeling asthmatic. The smell is almost gone but the VOC levels continue to be very high.
From reading about this product, it seems like off-gassing from the floor should be complete by now. The floor is hard so it seems like curing is finished. It has now been 3-4 weeks since the initial installation and over the past few days, the VOC levels were some of the worst that we have seen. Should we be worried that VOCs have leached into other materials in our home (carpet or drywall)? We are not sure why running the furnace worsens the VOC levels. Could there be a problem with how the flooring was installed? We are concerned that the VOC levels will continue to spike when we need to use the furnace in the future. Is this a problem that will improve over time or is there a risk that we will need to remove the flooring?
