Polyaspartic/Polyurea Flooring should I Trust??
G
garagewax
Guest
Hello All:
I recently spoke to a contractor about resurfacing my floor, and their application of a one-day coating system as follows:
Surface Prep:
Morning day of:
Diamond grinding and any necessary concrete repairs.
Base coat and flaking:
Afternoon day of:
Application of polyurea base coat and decorative flakes.
Protective top coat:
Evening of day one:
Polyaspartic clear coat.
Cure:
24 hours walk on ready
vehicle safe-24 hours, full cure in a week.
I just wanted to hear some expert opinions because I’m reading a lot of conflicting information. My garage floor is uneven, pitched to one side and has multiple cracks. The contractor claims limited lifetime warranty. The cost is around $7 a square foot. I’m looking at DIY kits for around $1000 plus equipment rental as a comparison to cost. Is this a good way to go about fixing the floor or are there better ways?
Thank you
67King
Friendsville, TN (Knoxville area)
Whatever you do, if you DIY it, don't put any water on the floor, or else you'll need to let it dry for a week. I've seen online guides that say after acid etching, let it dry a full 24 hours. That didn't come close to having it be dry in my case. Grind, sweep off, blow off, use acetone to "damp mop" it, and still give it a good 24 hours.
Andy Smith Jr.
Houston, TX
Run far away from one day floors and polyurea base coats. Also you should never drive on a floor 24 hours after install. Ever winder why contractors want to do a one day floor?
mrtynafixit
That system they're describing is actually pretty standard — polyurea base, flakes, polyaspartic topcoat is a legit professional setup, and the one-day thing is fine since both cure fast. The only part I'd push back on is parking a car on it after 24 hours. Give it 48–72 to be safe, especially with hot tires.
The thing to think about with your floor is the pitch and the cracks. A coating follows whatever's underneath it — it'll fill and bridge cracks if they grind them out and patch them first, but it won't fix a slope or level an uneven slab. So just get clear with them on what they're actually fixing before you sign.
On DIY — for a floor with cracks and pitch issues, I wouldn't learn on this one. Prep is the hard part and a rough slab makes it harder. That $1,000 kit looks cheaper until you add the grinder rental and the odds of redoing it. $7/sqft with grinding and a warranty included is a fair price.
One thing worth doing before signing: ask exactly how they're handling the cracks, and check that the warranty covers peeling and not just "defects." There's a good list of questions to ask a coating contractor at garagefloorsrsm.com if it helps.
