Polyurea vs Epoxy
Garage Flooring
Grand Junction, CO
There has been a lot of discussion lately regarding Polyurea, polyaspartics, and garage floor epoxy. The question that keeps coming up is which product is the 'best' We have an older article on our site that discussed that issue in depth.
garageflooringllc.com/2019/05/07/garage-floor-epoxy-vs-polyurea/
The truth is that different products have different advantages in different situations. I continue to believe that Polyaspartics should not be installed by the DIY consumer where Polyurea and Polyurea / Polyaspartic Hybrids are in fact a good fit.
Professional Polyaspartics has become a very good option. If you are hiring a professional contractor that has an office, location and is certified by a manufacturer to install and warranty a Polyaspartic system, it may be a very good option. Many of these products don't have great adhesion direct to concrete, and they are installed as a top coat. This is a very good application for a full broadcast floor, but I would question the benefits of doing it over a random or partial broadcast. My concern would be that unless there is a tinted layer of Poly between the base coat and the top coat, the epoxy can still yellow, fade etc.
There is NOTHING wrong with garage floor epoxy. Companies like ours (Garage Flooring LLC) , Legacy, Armorpoxy, and Alpha Garage offer high-quality garage floor coatings and the expertise to help you DIY them. In some parts of the country, 100% solids epoxy, and clear, despite the drawbacks (of clear epoxy), are more prominent because of the VOC laws in areas such as Southern California.
There are situations where epoxy is preferable to products like Polyurea. Interior home or commercial applications, especially with limited ventilation. Floors that are damaged and a less than perfect repair is being done or floors that have been repaired properly but did not come out as perfect as you would have wanted. Those who are sensitive to odors should only go with 100% solids coatings and check the SDS sheet first.
Epoxy tends to be a lower odor and is thicker than Polyurea products - per coat. Industrial epoxy for forklift applications, although not the prettiest, is also a good option. If you are doing epoxy 'just because' we find the DIY high solids kits are easier to work with for the typical consumer. You can use a roller throughout.
So what is up with Hybrid Polyurea, and why are people turning to it for their DIY garage floors?
(I am speaking based on our product, but much if not all of this holds true for the others mentioned above)
  • Polyurea does not typically have a part A and a Part B. So what? You would be amazed at how many jobs show up in forums like this where the floor did not cure because it was not mixed in the right ratio.
  • Polyurea will not cure in the bucket or pan. I suppose if you left it open long enough, you would have an issue, but assuming you are installing a garage floor over the course of a long weekend, there is no pot life. Over extended periods of time, solvents start to evaporate and the product starts to mux with the air.
  • The solvents in Polyurea make it more forgiving. Prep is still important but say CSP1 - CSP2 is going to be just fine.
  • Polyurea rolls on easier.
  • Polyurea is more UV resistant than epoxy. We all love to use words like 'Cycloaliphatic ' and claim that epoxy is UV stable. And it is to a point. But while we have some of the best UV rated epoxy on the market (so do others here, not trying to sell you) it still will not compare long-term to a Polyurea when exposed to sunlight -- from an open door or window.
  • Polyurea can be more durable in typical applications. Always check the chemical resistance charts if you have a specific need. Polyurea is not as hard as epoxy. At the same time, that might sound like a negative. Imagine dropping a hammer on a piece of glass. Now imagine dropping it on a trampoline.
There are some things that are equally important in both systems. Mil thickness. This is not to say that Mil thickness should be the same for a poly as it is for an epoxy. It won't.
It becomes a little bit of a marketing trick. Let's say I sell you a can of AWF Polyurea. Roughly speaking, its 70% solids. Now let's say Brand Y sells you their brand of Polyurea. Let's say it's also 70% solids. Now we tell you that the ideal coverage is 200 Sq. Ft. per gallon. Brand Y tells you 300 Sq. Ft is ideal. Which coating is going to be thicker on the floor? IT'S THE SAME AMOUNT OF MATERIAL.
The same holds true in a kit. We might send 5 gallons of Polyurea for 500 Square feet whereas another manufacturer might send four. All of our kits are based off of 200 Sq. Ft. per gallon.
So where does that number come from? The guys in marketing or the people in charge of sales want to inflate that number as high as possible. The Bean counters at the plants want to make that number as low as possible - so they can sell more products. We bypassed both. We went straight to our technical services liaison and did some calculations. The numbers were based on a point of diminishing return on increased thickness per coat. We factored into that number several things like the amount that stays on the inside of a paint tray or can and the fact that everyone wants to stretch things just a little.
We looked at these numbers from multiple brands/plants and determined that, hands down the best number for a Polyurea averaging 70% solids (ish) is 200 Sq. Ft. Per gallon.
While this example is based on Polyurea, these numbers are equally true for Epoxy. You are not getting more coverage you are getting a thinner floor. Big home centers will mess with these numbers even more. While our coatings may be ~90% solids they might sell you one that is 50% solids for 25% less -- or quote a system that leaves you with your garage half done because you did not get enough material.
Epoxy products SHOULD have a primer. Polyurea products don't need one -- with a few exceptions we see in Florida that have crazy porous floors.
[End rant] I'm sure there are more than one typos. Just wanted to clear the air on some of this
FJ4FUN
NorCal
Well said Justin, thanks for taking the time!
I might disagree on some of the points made, particularly as they relate to durability of epoxies VS polyureas, but understand that this is not intended to be an exhaustive deep dive into the various manufacturer's product features.
G
Garage Flooring
Grand Junction, CO
Thanks!
craigdt
This is super helpful post here.
I did a lot of research prior to coating my floor, and determined epoxy was right for me.
Very little odor (almost smelled good for about 12 hours, then went away).
The limited pot life was a bit stressful, and it didn't roll on just perfectly, but I was extremely happy with how it turned out.
Everyone who's seen it just gushes over it. The 6 year old neighbor girl walked over, gasped loudly, and said "THATS WONDROUS!"
link to my install:
https://www.garagejournal.com/forum...ngs-hand-ground-quick-review-and-pics.519146/
G
Garage Flooring
Grand Junction, CO
link to my install:
The important thing is you found a product that works for you and got it done. Great work
rayh555
rayh555
Hi,
I’m looking to have my concrete garage floor coated by a professional. I’ve got a number of quotes all pretty similar in price, prep & features. The difference being 2-3 companies mention they will use Epoxy base coat, full flakes & polyaspartic top coat.
The other 2-3 companies mention they will do a polyaspartic base coat, full flakes & polyaspartic top coat?
Looks like there is pros/cons with both. Epoxy being thicker & better bond to concrete & polyaspartic being no yellowing + 1 day process vs two.
My main question is will the epoxy base coat turn yellow if using a polyaspartic top coat?
What method would you recommend going with? Thanks!
G
Garage Flooring
Grand Junction, CO
Hi,
Just replied to your thread
floorman3787
Why would you say epoxy has a better adhesion strength but then also say that it needs a primer. I do not use a primer and i use 100% solid epoxy and i have not had any issues with over 300 garages.
floorman3787
Hi,
If you use a full broadcast of chips you won't even see the epoxy under the chips. Then a polyaspartic topcoat to prevent yellowing.
G
Garage Flooring
Grand Junction, CO
First. Hats off to you. 300 garages outstanding
If you have done 300 garages you probably know the concrete in your area inside and out. You probably prep the heck out of it somewhere at a CSP 2 to a CSP 3. The average person in here is doing their first or second garage. A large percentage of will do a relatively light grind or acid etch.
Typical adhesion testing is 450 (based on grinding and a primer). But that is based on proper prep and prime
Almost all manufacturers suggest a primer below their products and most who don't are not actually manufacturing them. It is my honest opinion that not using a primer, even as good as you are, is a problem waiting to happen. Many Polyurea coatings will test around 1,000 PSI. That will depend on surface prep still.
Full broadcast with 100% epoxy below and a polyaspartic top coat is a great system. But it is important to understand something about most clear coats, including Mot Polyaspartics. Polyaspartics are UV stable but they do not substantially reduce UV that passes through them -- unless tinted.
This means if you have a random broadcast floor or no media at all with significant constant sunlight exposure you will have a crystal clear top coat with a yellowed or discolored surface below it.
Now we sell epoxy for garages all the time. But if it is someone who leaves the garage door open or has other sources of UV exposure..... We highly suggest full broadcast or a Polyurea system
floorman3787
Yes i agree with that if not using a full broadcast. But im still amiss at how polyurea is harder and has a better adhesion then epoxy. I have seen statements but have yet to see a actually tech sheet with the astm. I worked for the company in sales that manufactures the product and spent time at the facility. I like a thicker build around 8mil with 100% solid and i broadcast about 15lbs per 100sf. I check the hardness of the concrete to assure i use the correct diamonds to get a good grind. I have also made a special attachment so it creates a suction to the floor and gets up all the dust. Thank you well the first 100 were on my hands and knees with a hand grinder. Now with lavina and full set up it is nice. If you have any tec sheets for you polyurea send them over id love to dive into all that.
G
Garage Flooring
Grand Junction, CO
I would not say it is harder. Most of the time epoxy is going to test 'harder' than polyurea, but that does not translate into more durable. The adhesion testing does make sense if you think about depth of penetration of a poly vs an epoxy along with other factors.
FJ4FUN
NorCal
As a side note... Primers perform many additional functions beyond adhesion. Example, both our BondTite primer and LiquaTile body coats offer bond strengths >1000psi (the concrete* breaks before the bondline) so, based on adhesion alone, you'd think that it would be fine to apply our LiquaTile body coat w/o a primer, and it would, for a few years... One of the benefits that a good primer offers is increasing the longevity of the coating system. Concrete is constantly expanding and contracting which, over time, will potentially fatigue the coatings' bondline. The BondTite primer has a few characteristics it uses to compensate for this. It is, for lack of a better word, slippery, so it will soak much deeper into the concrete than our LiquaTile body coat, plus it offers significantly lower flexural modulus and higher elongation (it's more flexible) so it acts as a buffer between the relatively dynamic concrete substrate and more static body coat. This all contributes to an overall coating system that lasts decades not years.
*It's worth noting that "typical" concrete fails at between 375-425psi so any adhesion bond strengths beyond that are somewhat meaningless in residential applications.
