Pool Heat Pump
D45
NW INDIANA
I'm looking at this heat pump to help with pool water temps this year:
Runs on a standard 3-prong, 120v outlet
According to the specs, it pulls 15.7 amps and requires a 20amp circuit
I know I have 12g wire and 20amp for my pool pump, but I need go check to see how much my pool pump draws first?
D
D45
NW INDIANA
I have a 110v 2 speed pump
I'll check the specs today on the amp draw
D
D45
NW INDIANA
Pump specs:
High speed is 11.0 amps
Low speed is 2.9 amps
D
D45
NW INDIANA
FH135 - 15.7 amp
Pool pump on LOW: 2.9 amps
Total draw is 18.6 amps
If I only use the heat pump when the pool pump is on LOW I wonder if it will be ok?
jmdirk
Check your local codes. Often pool pumps require dedicated circuits.
Shiftless
East Bay SFO
For example…
10,000 gallons is 83,000 pounds of water
So a 35,000 BTU heater would warm that water up at the rate of less than half a degree per hour if we assume absolutely no heat loss to the surrounding air.
D
D45
NW INDIANA
It's a 24' round pool, so maybe 13,500 gallons
Just looking for options to help heat the water
Not wanting to run a gas line
Shiftless
East Bay SFO
Ok
crunching those numbers, I conclude that a 35,000 BTU heater will warm up that much water one degree F about every 3 hours. That assumes no evaporative heat loss. You do have a cover, right? And no heat loss through the sides of the pool when the air temp is lower than the water temp.
D
D45
NW INDIANA
Yes I have a cover.......
1° every 3 hours of heat pump running
6 degrees in less than one day is doable
Not saying I have to run or use the heat pump all the time, but on days when the water temp is 70°, 6 more degrees will drastically help
Just need to determine if a $1700 heat pump is worth it
mike93lx
Richmond, VA
I have a heat pump for my pool and wouldn't even consider a pool without a way to heat it. Mine is 120k btu and costs about a buck an hour to run. Adds several hundred for the season and is well worth it
The comfort difference between 70 and about 80 is massive.
I use mine to maintain temp, not raise it for certain days. Keep in mind that ambient temps really impact efficiency.
