Poor Man's Oil Cups
Cleave
Back Porch
Old WF Barnes and Co #6 lathe, the spindle bearings oil cup holes are tapped 7/16"-14, not NPT like you'd expect. As such, no oil cups off the shelf will fit. And the bearings leak oil like crazy, so I don't want to run them dry by mistake.
So, here's my solution, with a couple bolts and some clear tubing from Lowes. Quick, easy, effective.
C
Cleave
Back Porch
Why not just cut off that bolt and tap for a proper fitting?
You sure could do it, and it would look more original with the right oil cups. But this was less work for the same end result, with what I have on hand.
The bolts are threaded into the bearing housing. The top of the bolt is turned round, and the clear tubing secured to the bolt head with a hose clamp. The nut holds it tight on the bearing housing. So no cutting off of bolt, just remove if desired.
Jim_No_Garage
Millington NJ
Forgive me but I'm still missing something. . .
Does the bolt have a hole drilled through it to feed the oil from the hose into the bearings?
I guess the oil could "spiral" down the threads, past the lock nut and into the bearing but that doesn't seem like it would work.
The only oil cups I have seen are on vintage fans where you soak the felt with oil and it flows over time.
Cheers
Jim
C
Cleave
Back Porch
The bolt hex head is turned round to a tight fit into the clear tubing.
There is a 3/16" thru hole in the bolt.
Rick B.
East Tampa
Good fix. I love fabrications for function. Only thing I'd do is shorten up the tubes and make some nicer caps. Great job.
paulsomlo
Northern Colorado
One concern I have about those "oilers" - how tightly sealed are the tubes above the oil level? Reason I ask, is that some Gits oilers have a small notch cut out under the cap to avoid a vacuum. Is oil flowing to the bearings the way you think it should?
C
Cleave
Back Porch
Yeah I did wonder about that but the oil is definitely coming down through. The caps are just little pieces of 1/2" oak dowel, no taper.
The front spindle bearing really uses a lot of oil. Any chance there's a way to tighten these bearings up?
paulsomlo
Northern Colorado
It looks like a split plain bearing up front - if there are shims in the split, you may be able to remove/reduce them. Not sure how they're doing the back, but the front ones take the brunt of the side loading.
C
Cleave
Back Porch
Thanks for the tip, I'll pop that front bearing open sometime and see if there's anything to unshim or adjust.
C
Cleave
Back Porch
Over the weekend I pulled of the upper bearing housing and top half of the bearing (front spindle bearing) that leaks oil.
Bearing surface was fairly chewed up, but the spindle is good enough. The mating faces of the bearing halves had what looked like one layer of wax paper as a shim, I removed this and reassembled. Seems like it doesn't leak oil quite as fast but its hard to say without running it for a while.
paulsomlo
Northern Colorado
Just make sure that the bearing is getting adequate lubrication - it is possible to set them too tight. While a film of oil doesn't take up much room, it still has finite thickness. I've heard numbers on plain bearing lathes of about 0.001" clearance. If you wipe it down good and can see oil dripping out the bottom of the bearing, you're OK.
PugetDude
Superstition Mountains, AZ
The best hillbilly oiler I ever encountered was a cat food can with a 1" wide x ~6" long piece of felt pop-riveted to the side. Can was filled with oil, and was mounted above a slow moving shaft.
Want to lube the shaft?
Pull the loose end of the felt out of the can and let it hang on the moving shaft.
Want to turn if off?
Put the felt back in the can.
Surprisingly, it worked pretty well.
