I want to buy that Milwaukee M12 rivet gun.
If it's any good at all, having the automation will produce cleaner results.
That thing is awesome...
I have a dock with a lot of rub rail...lots and lots of rivets. Whenever I need to replace a piece, along with about 50-60 rivets...makes it a piece of cake.
Does it break them off as cleanly as I suspect it does?
By hand, it's very easy to fasten the rivet securely, but also easy to leave too much stem, break it off at an angle, or at variable depth, in that regard.
I'm really looking forward to picking one up when I'm not backed up with other stuff.
Yes. Shears it right off flush....catches all the cut offs too.
I was worried about any sharp edges sticking out as there are bare feet and bodies rubbing on the rails all the time.
I will also vote for Astro Pneumatic. I bought an air powered unit and have put 1000+ rivets through it with no issue.
If I had it to do over again I would look a little harder for a unit that could also do riv-nuts with a change out of mandrels.
Astro:
- hand tool
- pneumatic tool
- tool that attaches to a drill, so that would make it cordless if you use a cordless drill
And a couple different choices in each type, at least in the hand-powered ones. Small one for small spaces, but you may have to squeeze the handles twice to set the rivet before a third pull to pop off the mandrel stem (because of the leverage/linkage on the tool), large ones with even more leverage (but are bigger), and even bigger ones to hand set 1/4" stainless steel rivets.
1422, 1423, 1426 are just a few of their hand riveters.
They make nice stuff. I've gotten to the point with the handful of Astro things that I've bought so far, that if I'm looking for a new tool I usually check to see if Astro offers something.
Astro also makes riv-nut tools.
And some that can do rivets and riv-nuts.
https://www.astrotools.com/
