IanF
I wouldn't mind hearing from POR-15 customers who, like me, have had successful applications of the product.
John
We'll let you know in the Spring as despite some reservations, we're still planning to go with this product.
John
I received my refund as well.
Chris and Dave, I appreciate you guys handling this appropriately. The product has flaws, but your customer service has been great since day one.
This is exactly what I fear!!!! I would sh@t if I went through all the work to have my floor peel anywhere that just bites...
So......... what is the best choice for epoxy type coating now ???
EPOXYPRODUCTS
EPOXYQUARTZ
PEBBLEROCKFLOORING
UCOATIT
ARMORPOXY
ARMORCOAT
BLAH,BLAH,BLAH!!!
JUST SO EVERYONE KNOWS POR-15 is NOT A EPOXY it is a Moisture Cured Urethane!!!!!!
What do you think this is some kind of product where i tell you all the info no i have to leave some stuff for you to find out on your own!!!!![]()
This was a joke GUYS!!!!!
Our products need to have 40f (slab temp)... Typically, the slab is warmer than the air temperature when you get to that temperature range. the floor can not be 'wet' but damp is OK if you prime with BondTite 1101. The lower temperature would drag out the cure times. We DO have some quick cure products that can be applied at an even lower temperatures.
If you have a new pour, if you use our BondTite 1501 as a curing sealer you won't have to do any prep! In addition, you won't need to wait 28 days either to coat the floor. You do have to wait at least 24 hours from the time you put on the BondTite 1501 before coating the floor (depending on the temperature).
well we know what POR-15 cost .. what does your cost?
