Porcelain Install Temps?
jeepnut24
Morrison CO
What is the recommended install temperature range for a Porcelain Tile floor? I live here in Colorado, and it looks like Id be doing the install in October. That means it will be cooler, but not yet frozen. Im afraid it will be too cold to install. However, I hope to avoid having to empty the garage in the Spring to install the floor next year. I got so tired of all the dust in my last garage that I really want something other than naked concrete in my new shop.
Angelfire
New Mexico and Ireland
This is really going to come down to which thin-set you are planning to use. Many of them work to an "ideal" 72F but go down to about 50F. There are admixtures you can add or rapid set thinsets to go even lower. Keep in mind as well that your substrate will likely be warmer than your ambient assuming your tiling on a slab on grade. Here's some reading for ye:
http://www.custombuildingproducts.com/media/60523057/extreme_tiling_wp130_2-15_web.pdf
Cave Creek Ray
North Central Arizona
I am no pro installer and I have installed both projects this far at this house in Arizona summer.
Mortar is a water based product that needs to stay unfrozen to cure. I am pretty sure your garage would be fine to start working, especially if you start the tiling at the door, which will require the door be open obviously, so doing that mid-day it should be at least in the high 50's up their. Once you get the area under the doors done, you could work comfortably indoors, augmenting heat with a fan-powered garage heater. I am sure your closed garage doesn't get below freezing in October so any tiles set should set up just fine before peak cold. Same with grouting. You can grout under the doors and have them closed within an hour. If your garage faces east, it should warm up with morning sun, same with west-facing garages in the afternoon.
The only hassle is the use of a tile saw but, you can lay the main body of the tiles and then cut the edges after the main body is laid. If you have a pattern, like herringbone, that will require a bunch of split tiles to straddle an expansion joint, you could pre-saw a bunch of those and then go to town, using the saw at the very end. You could put a tarp down to catch and mist from your wet saw. You can always hose your whole tile job down before grouting so, if you get some over spray on it, its not a big deal.
Sure... I'd go for it! Take lots of pictures and start a thread here!
Ray
J
jeepnut24
Morrison CO
It is slab on grade, and I suppose I could rent a heater to bring the air temps up. At that point in the year, it should still be in the 50s for the most part. Maybe not over night. We can get some freezing temps at that point in the year.
The alternative is a coating of some sort... But I think Im hooked on the tile from reading all the threads over the years.
Dakota00
Woodbridge, Ontario
You would need to keep the temp at or above 50F especially for over night so the thinset can cure properly.
Renting a heater (if need be) wouldn't be a bad idea!
