Porcelain tile stained during install - clean up?
PecosBill
Oregon
Please tell me you did not use any of those adhesives on a garage floor.
The link is not working for the tile, and which of the adhesives are we talking about?
How about posting a pic of the actual stain?
bochnak
Mt. Prospect, IL
No. This is for a bathtub wall.
http://www.rocatilegroup.com/index.php?option=com_k2&view=itemlist&task=category&id=54:stratos-orion
Adhesive is the large tile 20x20 type.
I'll try to post one tonight.
I called the adhesive mfg and they recommended mineral spirits.
Warrenator
Newberg, OR
If mineral spirits doesn't cut it, you can experiment a little, lacquer thinner, acetone, MEK. Gloves, ventilation, mask, safety specs. Acetone is probably the safest of the more aggressive solvents, we used to use MEK in squeeze bottles for cleaning but apparently that's not good for your liver....
I use a Q-Tip dipped in solvent and look to see if I'm getting any adhesive up on the end of the q-tip, kinda an experimental thing before soaking down the whole tile.
PecosBill
Oregon
If the manufacturer recommended mineral spirits, I would go with that.
Sometimes you can get an oily residue from the reaction with the adhesive. If that happens a degreaser should clean that up, with a poultice in extreme cases.
