Porcelain Tiles Cold climate
Eric_C
I originally wanted to tile the entire garage.
My wife had reservations about it because of the weather. She tiled the rest of our home. So we were going to tile a riser that runs around the garage and then epoxy the rest.
I still keep going back to tile especially after we prepped and measured the floor and across 28' there is less than .25" inch of change in height. Whoever poured it did a perfect job.
It is prime for tiling but she is worried about the cold weather. The garage is fully insulated including the doors and is attached so it never freezes inside. It doesn't even get refrigerator cold in there. When we have a party or something we have to put the drinks on the deck to get them cold, the garage stays around 45-50.
I thought the whole point of porcelain is its ability to withstand temp changes if the right mortar is used.
We bought a 12x24 tile from Home Depot that we liked for the riser and I'd like to use it for the rest of the garage because its pretty inexpensive, $1.99 per sq. ft. but my only concern is the size of the tile.
Is that too big if its put down properly and evenly?
We did a lot of prep work for epoxy but still read too many stories of it not going well. A $700 risk that required a near complete rework and most money spent if it does not work or $5 to fix a bad tile here and there with something we already know we can do.
Dakota00
Woodbridge, Ontario
When using the proper tiles, thinset and grout for an exterior application, the cold weather will absolutely not affect or cause any harm to the floor. I just need to know the tiles specs to make sure it's suitable for the intended application.
Installing 12x24 tiles due require a bit more skill and time to lay, but as long the base is fairly flat there shouldn't be any concern for getting the tiles nice and even.
When you are ready, let me know. I'll gladly help you out along the way!
Jack Olsen
Los Angeles
Freeze/thaw cycles are a fair concern, although it doesn't sound as though you're going to have that to deal with that. By definition, the water absorption rate of porcelain tile is less than .5%, which means it is able to withstand freeze/thaw cycles in exterior applications. (As Dakota points out, the thinset and grout also need to be able to withstand freeze/thaw cycles.)
But again, you're just talking about the tile getting cold. I can't see anything to worry about at all with that.
Dakota00
Woodbridge, Ontario
Thanks.
We looked into Tec Specialty SuperFlex mortar as it is supposed to handle temp changes well.
This is the tile we were considering:
http://www.homedepot.com/p/MS-Inter...all-Tile-16-sq-ft-case-NMETGRIS1224/203673201
However after getting more serious about this we wanted to see what else we liked.
We like your design but we'd like it to be a bit darker but same idea.
Home Depot carries FlexBond thinset and Lowes carries Kerabond and Keralastic thinset system. Either would be ideal for your climate.
The tile you have in mind is a very nice medium duty porcelain, which will hold up just fine under normal abuse. In a garage setting, I wouldn't recommend it if you're a ******** weekend warrior that does a fair bit of mechanical work on the vehicles.
E
Eric_C
We went with a different tile:
https://www.lowes.com/pd/Del-Conca-...n-x-24-in-Actual-23-5-in-x-5-84-in/1000046237
After putting it down on the floor and looking at it, too dark with the walls. This is much lighter in person than the pictures show. A very pale grey, not a hint of brown like the pictures show. We took some pictures and it had that same brown look but doesn't in person.
We will see, 750sq ft being delivered tomorrow.
The garage will get a fair amount of use. We've run track days for years and I'm going to build an early 2000's Corvette specifically for the track over this winter.
My current Corvette is new so not much to do to it besides change the oil in the motor and in the supercharger. I might end up doing a wide body conversion on it but that's fairly light also as far as equipment and possible damage to the floor.
Mostly wanted something near zero maintenance that was nice. We finished painting, all new trim, crown molding goes up tomorrow.
