Portaband Stand
Reata210
Home
Thought I’d share a couple pics of my stand. Took a few ides here and there and came up with this. Saw is mounted with a tab in rear and toggle clamp. No mods to saw and can unplug and be removed easily for portability. Cuts perfectly square. Thanks.
isb cornbinder
Nicely done. Way nicer than my "good-enough for now"
Years ago, before I bought a Delta/Rockwell 2 speed 14" bandsaw, I made a simple bolt on table for my horizontal metal saw. My simple idea worked just OK. My horizontal saw was made "over there". I am surprised that it has lasted for over 20 years of heavy use.
R
Reata210
Home
Thanks! The clamp is from HF, basic toggle clamp. Think its rated at 5 or 600 lbs of pressure. The clamp secures the stock foot/guide of the saw. The rear tab is welded on. The full weight of the saw is on the tab and the clamp locks it in place. I cut all material with the bandsaw and cut the kerf with cuttoff wheel along a straight edge. Light comes on as a pilot when saw is running. Saw also has an led work light. Like others I velcro’d the trigger. I’m not much of a fabricator so I went basic but useful. Will be nice not to have to break out cutoff wheels all the time for materials.
