Portable AC in Trailer
BillC6
Florida
I am thinking of adding a portable AC unit to by trailer. I an thinking of drilling a hole in the floor for the intake, exhaust and drain. A few questions….
Has anyone done this?
I read about 2 tube units that do not exhaust the interior air in the exhaust tube, seems better but I have not found any. Any experience on this?
How about noise, any recommendations, good or bad?
Thanks
Bill
BillC6
Florida
yes, I store the trailer in my garage. Built the house with 8 foot tall doors and ordered the trailer with out a roof vent so it would fit. I have 1.5 inches to spare.
Larosa
new york
no idea with this thing and i havent done this yet ever in my life. better to contact the moderator for this query.......
koditten
Midland, Michigan
I bet it would work. I know from experience they don't work for **** for an 800sqft shop. Your trailer is much smaller.
Btw, you can have mine, just come and get it. :)
fiveohpatrol
Bloomington, IN
I've seen quite a few guys at the racetrack try this, and not a single one I've asked has been even the least bit happy with it. I think you'd be better off going the redneck route and sticking a window unit thru the front wall.
Any route you go, insulation will be key. After all, you are trying to cool a big hollow tin can. I put a 13.5kbtu roof unit on mine (24ft enclosed) and even that didn't do much until I insulated the roof. Does pretty well now, but the walls could use some insulation too.
BillC6
Florida
Thanks for the responses. I insulated the roof and will do the sides based on the AC performance. I hate to cut the front. One person who did said he would not do it again because with rain and the air pressure of highway driving drives water to find a path around the edge seals.
I also thought of building a box like a generator box and housing a window unit in it, venting from the side to the bottom, but i concerned about the noise and exterior air / heat flow. Plus for saving $200 it is more work and may not work.
Please keep the ideas and experiences flowing.
CNGsaves
KS and OK
Let's see some pics of trailer.
What about beefing up one of the rear doors so it would hold a window unit A/C that could be installed just when you're onsite?? Then have a plug that would cover that hole in rear door while driving. This would enable the A/C unit to ride in the pickup bed where it would be kept safe.
Another idea . . . APU (auxilliary power unit) like the diesel trucks use for powering/cooling that could be held in pickup bed, and just pipe over the cool air to trailer??
Kevin C
Portland OR
Not all portable air units are total pigs... Check the efficacy rating on them. Some have an EER of about 9 (esp the older units). I picked up a 14,000 BTU with a rating of 11 ( single tube). Not quite as good as a window unit, but good enough.
The only down side is if the pump does not cycle you may have a big puddle (heat mode) and they are more expensive. For aesthetics I did not want a window unit.
I also have a really well insulated shop.
bazzz
Heathsville Virginia
I had one of those portable units in my 6 x 12 trailer. The trailer is not insulated and it did not cool the trailer, basically wasted effort installing the thing. A friend with a similar trailer installed one of the RV units on his and it worked MUCH better. I don't remember the BTU of either unit, so it may not be a fair comparison. I would guess if you put enough BTUs in there it should cool it though.
Southernbuild
North MS
Ive got a portable AC unit in my 16' trailer. I insulated the walls with 1" Styrofoam, it had insulation in the ceiling when I got the trailer. 4" vent in the sidewall, and a drain tube through they floor.
