stickshift
Looking at portable air tanks online, it appears they don't have a drain hole. How do people get the water out? Periodically flip it upside down to make the one hole in the tank the low spot and then open up valve?
Sounds like a good approach, thanks.Once a year or after X number of uses, turn it upside down and vent the schrader valve. If a teaspoon of water comes out, X is just right. If more than that comes out reduce X. If none comes out increase X.
I just turn it upside down and let the residual air pressure purge it.While on this subject,I noticed the red ,5 gallon Craftsman I bought a few years ago has a coating inside of the tank so will definitely never rust thru considering the amount of use it gets.But even with the coating it still has a "discard by 7 years from May 2017" stamped on the bottom of one of the feet.
Let us know what you find!I've been using the same portable for at least 30 years. Never even thought about draining it. Guess I'll have to try that and see how much water I've been lugging around.
Have had this one since about 2005. Put a new valve on it in 2016. That tag has been bugging me lately so took the valve off to have a look. A few drops of water dribbled out from the gauge it looked like. Inside had a little rust but not bad. Not sure what the powdery blue substance is. Paint I guess. Not sure why the inside would be paintedI've been using the same portable for at least 30 years. Never even thought about draining it. Guess I'll have to try that and see how much water I've been lugging around.
