Portable generator support legs
D45
NW INDIANA
Troy Bilt 5000 / 6250 portable generator
Briggs 14.50 hp motor with Electric start
Generator is solid and heavy and the support leg is too flimsy
Any ideas for a new support leg setup?
D
D45
NW INDIANA
Yes. It already has a wheel kit
The OEM support leg has been hammered and bent alot, looking for something better
mmb617
PA
I grabbed some scrap I had and made my own legs. I'm pretty confident in it's sturdiness now.
JWILLIE1977
WNY
I have several Generac & Powermate 5000 watt generators with the 10 HP Tecumseh. After the "legs" became useless, I used a stack of hockey pucks to replace the legs.
I think each uses 2.5 pucks per leg. Drill the pucks and bolt to the frame. I think there were holes in the frames to bolt to already. Was cheap and easy for me.
D
D45
NW INDIANA
IIRC, hockey pucks are all 1" thick
I bet I would need 4 or 5 to make the generator frame to sit level
JWILLIE1977
WNY
Yes, the hockey pucks are 1" thick. If you have large pneumatic tires with your wheel kit, probably take a a bunch to get level. I got my pucks from a used sports store. . for $1 each.
Suggestion #2. Along the same lines as suggestion #1. . Get 2 of the largest rubber mallets that Harbor Freight has. . . $4.99 each maybe. The heads on the BIG mallets are easily 5" face to face.
Remove the heads from the handles, and drill a hole through the head, from face to face. Cut to length. A couple long bolts and nuts. . Done.
Get fancy and countersink the bolt head.
I am partial to the rubber foot ideas bc my generators are always in the back of the truck running. The rubber keeps the generator from walking during use.
D
D45
NW INDIANA
Northstar legs are a good idea, but the wheel kit they come in is $150+
Support legs aren't sold separately
jives
Central NY
Same thing happened to my Briggs generator. I added a new axle and wheels to turn it into a 4-wheel wagon. Much easier to move around. I had a couple of cheap HF or TSC wheels lying around, bought a length of 5/8" steel rod, used a couple of u-bolts to bolt the axle to the front end of the frame, put on some large washers and the wheels, and viola'. . .an easily movable genny wagon. Mine now looks like the genny below. If I had to pay for the wheels and u-bolts the total cost would have been about $25.
  • Like
Reactions: D45
JRC3
Southwestern OH
At very least a model number of the unit might help. Can't even guess what might work without even being able to Google a picture.
D
D45
NW INDIANA
I like the idea of adding a front wheel kit, it would roll and move very nice.......but keeping it in one place during usage might be an issue
D
D45
NW INDIANA
Looks interesting......need to find the length of each leg
Briggs 312510GS
Might work
