CooperS7777
I've got a dock project coming up that is going to involve bolting some aluminum c-channel perpendicular between a couple of i-beams. The bolts will run through the lower flange of the i-beam and the lower flange of the c-channel, with the web of the c-channel perpendicular to the web of the i-beam. The i-beams are already installed, therefore both c-channel and the i-beam must be drilled and bolted on site. To add to the complexity, the I-beams extend out over the body of water.
My initial plan was to use a couple of kant clamps to secure the c-channel between the two i-beams, and drill through the i-beam and c-channel from the bottom. I have been considering how I could setup something similar to a portable drill press which would allow me to drill squarely through the i-beams and c-channel, when I stumbled across the rapidrill ( https://www.trick-tools.com/15001-Rapidrill-SLIM-Mobile-Drill-Press-14342 ). I feel as though this would be the perfect solution for this project, however, it doesn't appear to be available anywhere. I have reached out to the mfg, but have not heard back.
Does anyone have a link to a similar product which is currently available, or have any other creative solutions aside careful hand drilling of these holes?
EDIT:
The i-beams in this build are functioning as beams for a "deck" and the c-channel will be functioning as the "joists". When finished, the platform will appear as a deck, with two sets of bunks on it. The entire unit will actually function as a jetski lift, raising and lowering into the water. The I-Beams are cantilevered, so the upper flange will be in tension and the lower flange will be in compression (opposite typical i-beam forces).
The photos attached show what Im currently working with, and what the end goal is.
EDIT:
