Porter-Cable 60 gallon Air Compressor
daddycreswell
Middle Tennessee
rburke65
Canfield, Ohio
I bet it does. I bought a 60 ...2stage Champion from TP Tools and it supplies plenty of air and keeps up well. I don't know about the possible TSC PCable.
MoonRise
Sandblasting is generally not "very light uses".
That particular compressor is rated at a 50% duty cycle. So, 1 minute on and 1 minute off.
Compare the blaster's listed CFM needs versus what the compressor lists as it's output CFM rating.
Check the specs on your sandblaster and see what it claims it needs as far as air supply cfm. Keep in mind that the air needed by a blaster is very dependent on which nozzle orifice you are using.
If the compressor CFM supply is greater than the blaster's CFM need, you are maybe OK (still have to consider duty cycle). If the blaster's CFM need is greater than the CFM supplied by the compressor, then you are not OK and will either be waiting for the compressor to 'recharge' or you will exceed the duty cycle rating on the compressor (and possibly burn either the pump or the motor out). Or both.
Just an FYI, the IR 60 gallon 5hp unit that TSC lists has a rated 100% duty cycle and is rated at 14.1 cfm @ 90 psi and 16.1 cfm @ 40 psi.
http://www.tractorsupply.com/tsc/product/ingersoll-rand-5-hp-air-compressor-60-gal?cm_vc=IOPDP2
Falcon67
Merkel, TX
Bah. I use mine for blasting in a big HF blast cabinet. Sure after a bit you have to take a break, but you usually have to anyway to turn the part or check progress. I'm not a production facility, I can spare a few minutes here and there. Same with head porting, grinding, working a cutoff wheel, etc. I've had my CH version (also $399) for about 15 years. Pretty decent compressor for $400.
I would agree that a 14 CFM 5HP unit at $650 is also a very good buy if you can spare the extra $250.
strutaeng
Dallas, TX
Orange65
Clanton, AL
I have that air compressor- just got it a month or so ago. I like it. Works so far but only for airing up tires. The break in procedure is a 30 minute continuous run, so I would say it is good for at least 30 minutes of continuous running. I plan on using mine for some sand blasting eventually.
