Porter Cable Multi-Tool
Stuey
28m above sea level
Posted my full Porter Cable oscillating multi-tool review earlier this morning.
Nutshell version:
*2.5A motor shows its power
*tool-free blade change!!
*decent accessories/blades to start with, with an adapter on the way that will allow the use of other brands' attachments
*nice price - <$120 street, ~$140 list)
*very nice construction - feels solid and durable
*long durable cord, oversized plig
The tool-free blade change is a little stiff, but that only means that it can be used for hand grip exercises. =P
I give it 2 thumbs up and a positive recommendation.
Stuey
28m above sea level
I have to admit, I really didn't think that the tool-free blade change would work as well as it does!
What are you thoughts on it?
wafrederick
Holton,Mi
Does not beat the Fein Multimaster and Fein fully stands behind their power tools.The Fein Has the better tool free attachment,pull the lever and remove the pin and doing the opposite when putting the pin back in.
327-365hp
Central Mass
I have a question on the Porter Cable. Are you able to orient the blade in any direction. IE; left & right or only straight ahead.
Stuey
28m above sea level
Most blades can be oriented in a range of directions. This is shown in the second to last image in the multi-tool review.
Since that image is a stock image, I went ahead and tried most of the different blade types just now, and they all can be rotated into the desireable position. I do believe that most other tools offer this capability as well.
MrMark
Southern Cal.
Stuey, how does this one compare to the Bosch Multi-X. PC has become a poor tool company in recent years. It went from the best in sanders and routers to Dewalt's B line, if such is even possible.
Stuey
28m above sea level
Thanks for the reply Stuey. I use a Fein almost every day and the blade release on that is very stiff.
I'd bet they have to be stiff in order to ensure the blade/attachment is perfectly secure.
That said, the PC's tool-free unlock lever does require a bit of finger or hand muscle to squeeze open. I don't think that the spring should soften with time. If you have to change a blade every minute, you'll get tired fast. I can see how changing blades a couple of times an hour several hours a day can get tiring too. Although not nearly as tiring as having to deal with a hex key each time.
I was not bothered by the PC's somewhat stiff/strong blade-change lever. I figured that if it did become a problem, I could easily devise a cheater-bar of sorts to make frequent changes easier on my hands. While this would add a slighty delay, it would require less effort and would still certainly be better than dealing with a hex key and bolt.
I have not been able to get my hands on the Bosch Multi-X for prolonged review, although I did try it in action a few times here and there. Still, I can't really offer a reliable comparison right now. If pressed to offer a subjective opinion, I would say that the tools themselves may be comparable in terms of quality and performance (hard to say at this time, really), but that perhaps Bosch has an upper edge in accessories given their greater experience and head start. There's also a bit of a price gap between systems. I don't think that either the PC or Bosch is a lesser tool. But again, I have not yet done the testing to really support this stance.
That said, I am confident that the PC tool is intended for professional use. I actually made the mistake of initially assuming some of the new 12V max tools were targeted at the same audience as the inexpensive 18V tools offered at Lowes. I was wrong.
As for Porter Cable being Dewalt's B line, I don't see that happening at all - they've got their own identity, and it looks like they're working hard to show it. Now, with that said, it does look like they're somewhat price conscious, without having to sacrifice any essential features or build quality. As you can tell, I've had a lot of time to think about this and make my mind up about the company.
Actually, quite a few of Porter Cable's most recent new tool releases surprised me with how great they are - the 12V drill, driver, ClampSaw, quik jig pocket hole jig, circular saw, and compact router. The 12V drill and driver are far from being the most compact or most powerful on the market, but they offered great performance and quality at a reasonable price. The circular saw proved to be superb, and the router as well. The router does leave out the variable speed control and LED worklight that Dewalt's version offers, and its base is different, but in use this didn't make any difference.
I was an outspoken skeptic. I mean, a $90 (on sale) cordless drill and circular saw kit? The older Porter Cable cordless drill kit used to cost double that by itself. But aside from those few inexpensive mid-level big-box store tools, I feel that PC has been showing their true colors in the other tools they've released in the past 1-2 years.
RKA
That may be true (I don't know, never tried the Fein personally), but the PC is 1/3 the price. Apples and oranges.
What if the Fein was $199? At full price the Fein is tough to swallow (still have the dust collector stuck in my throat), but I recently got an email from CPO with open box Fein Top kits for $199 which made me do a double take. Link below but not sure if it'll work.
https://www.cpofein.com/on/demandware.store/Sites-fein-Site/default/Cart-AddToCartEmail?pid=fenrfmm250qtop-r&ref=feinopenbox&ref=em20110715
Stuey
28m above sea level
I'm seeing $350, not $200. Sometimes CPO's open-box/refurbished deals are for a very limited time.
Right now the Porter Cable tool is $110, and the Bosch $140. It's hard to say which I would personally choose. I have seen others' comparisons and reports of the Fein, and it does seem that they have an edge over other models. Besides, they've led the market for so long that they must have susbtantially more experience. I have not checked recently, but it looked like Fein's accessories were also quite a bit more expensive than the other brands'.
If I were buying my first multi-tool today, the Porter Cable would be one of the top choices based on pricepoint. The Dremel Multi-Max is comparably priced but long in the tooth, although two new models are due out this Fall.
From what I've seen, it is incredibly difficult to choose between the cheaper-than-Fein options on the market today. Each brand seems to have their own advantages, but overall performance is usually described as comparable. I am not willing to do a comprehensive comparison, but one of these days I may do a rough compare-contrast.
I was considering reviewing the newer Bosch version, but I haven't seen too many requests, and right now have too much on my plate. The Fein is way out of my budget and I have not yet looked for one to borrow.
RKA
On the blade front, the PC blades I saw in store looked like the stuff I see in HF (perhaps not as cheap and flimsy, but not far off). Fein is $$$$ and not easy to find when you're in a pinch. Bosch OTOH has some decent blades (last couple I saw were swiss made), they are readily available, and they have made an adaptor for the Fein and several other common multi tools. The quality of attachments available would probably factor into any decision if I were buying today.
Incidentally, I borrowed a friend's HF tool to plunge cut a small hole in some plywood since my father was borrowing my Fein. The blade worked loose on me twice (didn't want to overtighten it with the wrench), and the blade was thin and flimsy with virtually no bite. If his tool could be fitted with a decent blade, I'm sure it would be worthwhile, but as it was, I found it frustrating to do what should have been a 15 second cut.
Stuey
28m above sea level
My records show that the Fein was $210 back in November and $250 in April. I was tempted to pick one up back then, but there weren't enough bundled accessories for my linking.
As for the HF model, I've heard good things and bad, but I wouldn't touch it with a 4-foot pole.
