Porter-Cable Pancake compressor needs repair
SkyMaster
Canada
My father has a 16 years old, made in USA, Porter-Cable Pancake compressor.
I suspect that it takes more time, than it used to, to fill up. Also when it stops, it makes a scratchy metallic sound.
It is the model CF1400, just like that one:
View media item 42306
My father is still using it, I do not want to dismantle it, then wait for replacement parts to arrive.
What are the parts that typically wear out in these kind of oil-less compressor, and that I should order?
readhead
Durango, Co.
I would be surprised if parts are even available. You have discovered the problem with "oil-less" compressors. The price of compressors has dropped a lot over the years and I think you would be better off buying a new one.
b-body-bob
Almost Heaven
Brand new those small P-C pancakes are under $100 at any big box store. I broke down and bought a 3-1/2 gallon one not long ago, I think it was $89.99 at H-D during a memorial day sale.
LS6 Tommy
Northern NJ
Most all of those oilless pumps have have a one piece connecting rod & piston without a wrist pin called a "Rocking Piston", so the piston doesn't travel in a perfect vertical path. It "leans" left & right in the cylinder bore in relation to the crankshaft centerline as it goes up & down.They usually have Teflon piston rings and they do eventually wear out. I've even seen one super cheapo unit with a fiber reinforced plastic piston/conn rod! I think it lasted for maybe 50 hours of intermittant run time...
If it's making a "scratchy" noise, it's pretty much time for a new one.
Tommy
kbs2244
The most common problem I have found when taking them apart is tired or rusty reed valves.
I have never seen any different ones no matter the make or age of the compressor.
They are a truly universal part number.
They should be well less that $20.00 per set.
If you cannot find one under your make/model number just get one for another.
The last one I did was over 20 years old.
I took the valves in to the local construction tool dealer that offer repair and parts.
I just gave them to the counter guy who didn’t bother to ask about the machine.
He just went in back and came back with the new ones.
CJCar
South Central PA
