Porter Cable Polisher
kneisska
MN
Just wanted to check with you guys to get your opinion if this tool.
I've been waiting for a good deal on a high-quality car buffer for a few weeks now. In particular, I've had my eyes set on a Porter-Cable 6-in Variable Speed Random Orbit Sander with Polishing Pad 7346SPR. I've also been looking for a (same brand) 7424XP.
Anyone have any luck with different buffers that are a few dollars less? I'm trying to find one with the clutch built in as it seems those are best for getting rid of clear coat swirl scratches.
I'll take any suggestions seriously. Thanks in advance!
:Mr.T:
cptzippy
Leavenworth, KS
The PC is a good tool but for about the same money I'd recommend the Griot's Garage 6 inch DA. I would't get any cheaper and both of them are well proven in the detailing world.
alvoski
I've heard the griots and the meguirs 6in da are just rebranded PC's
Oldtymeflyr
Littleton, CO
I have had the sander version of this tool for maybe 15 years and use it as a polisher as well.
I have used it a lot and its still going strong. I would buy another one. Its easier to get a PC tool repaired if necessary. I have not had to get this tool repaired.
Its a very good tool.
Good Luck.
pipsters
USA
I have the 7424xp only issue is you have to use the smaller pads, as the 6" ones tend to slow it down too much. But the 5" ones are fine.
K
kneisska
MN
Sounds like a toss-up between PC & Griot's.
I was using a B&D 6" sander/polisher for a long time but I cannot find appropriate pads to use with it anymore. Plus, it makes terrible swirl marks. I could be using the wrong pad too...so than I just retired it to sanding-use only and have been polishing the cars by hand. Honestly, I'd rather spend 3 hours on each vehicle instead of 6 hours it takes by hand.
If anyone else reads this, feel free to suggest your personal favorite buffing tool.
Later!
cptzippy
Leavenworth, KS
Flex is a nice piece of equipment but at almost $300 it's more than twice the other too. It also runs a higher risking of burning paint due to the forced rotation.
FWIW, I have an old PC 7336 and it works fine. If I were buying one today I'd forgo another PC and get the Griot's.
Daedalus
I have the 7424XP and it works fine. I use Lake Country pads with Zaino waxes.
MrMark
Southern Cal.
Flex XC 3401 VRG
http://flexnorthamerica.com/products/XC3401VRG.php
Flex vs. PC
<iframe width="420" height="315" src="http://www.youtube.com/embed/Yht1uHJLNlQ" frameborder="0" allowfullscreen></iframe>
I'm sure the flex is a way better machine and I will get one myself to replace my PC (more than 15 years old) BUT that guy on the video has no clue. He is going at least 3 times too fast with the PC to get good results. You have to apply a bit of downward pressure (say 20 pounds) and go very slow, maybe an 1inch per second to work on heavily distressed panels like that.
Unfair comparison.
Monte
Germany
but it seems the Flex works better and faster, like twice as good/fast ...so twice the price :) ;)
The lifetime of the Flex tool will be most likely also higher...like twice as high :D
<iframe width="560" height="315" src="http://www.youtube.com/embed/ir8mA4vbgoI" frameborder="0" allowfullscreen></iframe>
cbracer
Costa Mesa, CA
The Griots and Meguires are now the same thing. PC's older model was the same as the Griots and Meguires didn't have one back then. But now PC has updated their model, and Griots and Meguires have their units made by the same place. Not sure but it's likely PC. I use my older PC for everything from buffing the car to sanding to grinding.
PCMusicGuy
Houston, TX
I have the Flex, and it's not that bad. You won't burn the paint on any modern car's paint job. I real issue I have with the Flex is that your pad choices have been limited. 6.5" pads don't get into tight spots. They have an adapter kit these days that lets you move into smaller pads but I've yet to try it. It's also a big polisher so it's heavier than you might want to use as a beginner.
I would recommend the 7242XP. It's a great starter unit. You can usually find them for a good price on the used market through message boards. Some places you buy will give you a 10% discount for being a certain forum member, i.e. autopia, corvetteforum, etc.
