Porting tools
illmatyk
Yigo, Guam
Haven't been here the last couple weeks but after much disappointment from people not being able to keep their words, can someone recommend me some good porting/polishing tools?
Also, pics or links to what you have would be nice also:thumbup:
Thanks!
RM209
MD
Eastwood also sells porting kits, but I suspect Summit is cheaper. Standard Abrasives has a nice little starter set of stones and rolls that can be purchased on line from numerous outlets.
Good Luck
justanengineer
Motor City
I would recommend saving your money and investing in a better set of heads/TB/manifolds etc unless you have serious money to play. Porting seems like a common sense, cheap, and straight forward way to make more power, but flow through heads is a rather tricky black art in many cases. Minor changes to port geometry quite often have a major impact on the flow, and predicting whether its an improvement or not is almost impossible. Unless you have a good quality flow bench (not a DIY POS) and multiple parts to experiment on, you might just end up ruining good parts.
Sancho
The backwoods
Mix of carbide burs in various shapes and a eastwood kit or two along with some time and good light and your rolling. I find it to be relaxing work, go slow.
jeepfan93
Toms River NJ
I prefer the Eastwood porting kit. I have the 4 piece long reach carbide tools, then use the Eastwood sanding rolls, again on a long reach arbor. The carbides have held up well after 6 sets of heads. The long reach really allows you to get where you need to. I haven't found a tapered sanding roll that will stay together after 10 minutes. But that may be more techinque than anything else.
