positioning of mini split in garage shop
Mister Ed
Hi all -
I have a new mini split for my garage shop and having trouble deciding where to install the unit on the wall.
Probably the best location would be right behind/above my milling machine. My big question is, with 8' 6" walls, how much of a breeze am I going to feel if I am running my mill?
Thanks, Ed
Steve W.
Southwest oHIo
They say a picture is worth a thousand words.
In this case, those thousand words would be all the requests for pictures.
Mister Ed
Yeah, I was thinking that as I was typing ... and taking pics when you were replying, LOL. No comments on the mess ... its winter and I have just been pulling some things apart to rearrange.
Thinking about this more ... above the mill will not work due to the window. So then that would put a couple feet down it above the toolbox, besewn the windows ... same question though ... how much wind/breeze should I expect if working at the workbench in front of toolbox.
Other easy option would be on other wall between corner & the wooden shop cabinet. Still in line with workbench ... but probably 4 more feet of distance. Left side exit of lines might be a PITA.
PoorUB
Fargo, ND
It really doesn't make a big bunch of difference where you mount the head. Just put it where it will be able to blow air around the shop the best.
Mister Ed
I understand I can put it wherever. The original question was, if working in front of it (say 4' from the wall), with 8' 6" ceiling height, how much breeze do you feel? That will be the determining factor if it goes in the location I want it to.
PoorUB
Fargo, ND
Don't put it where it will blow on you the majority of the time. Some is unavoidable.
Slednut
Washington state
This, I feel it really matters how hard it has to work and the model. Our Mitsubishi's is a nice gentle breeze in our house but standing in front of the Mr. Cool in the shop is not a place you want to be for very long.
Mister Ed
Thank you! ... that is EXACTLY what I needed to hear. It sounds like I should rearrange some things and move that big wooden shop cabinet.
chinboys
Most decent wall-mounted evaporator units will have adjustable and or oscillating vanes to direct the air via its remote.
The intake is usually at the top and the output at the bottom of the unit.
I usually pair my evaporator units that are mounted on the wall or ceiling with a ceiling fan to further distribute the conditioned air.
dsimatt
One thing to think about is maintenance as the blower wheel will get dirty and would be nive not having to reach over things to get to it.
flippin
Montreal - Ottawa
From my experince here's some advice, also spend some time thinking about the location for the outside unit. I regret moutning the compressor/heatpump on wall brackets. The unit does make noise and vibrates enough to hear through the wall (brick, 2x6, insulation, drywall). I have a tackle bench in my boat house and the outside unit is on the wall directly behind the bench. When I am sitting at the bench, I can hear the noise/vibration too clearly. I will try to add some dampening (rubber feet) to the compressor when the snow melts in the spring. Doing it again I would install on the ground several feet from the building.
Another thing which I would do differently would be to install a piece of stainless steel to the wall before mounting the blower unit. Mini splits need to be rinsed off and cleaned every year to avoid mold/smell issues. Amazon sells bags that will contain the drippings and overspray, but staining the painted walls is still a possibilty. If the stainless doesn't match the decor, painted steel (think exterior cladding without ribs) or even melamine would be a perfect choice too. A piece bigger than the interior unit would be cheap and easy to install in advance.
Lastly the interior blower needs a condensation drip tube. Draining this tube should be part of the thought process.
Don't get me wrong, I absolutely love my mini-splits. I have one installed in my garage shop and another in my boat house. I would give up morning coffee for a year before giving them up!
Fueler
Urbana, IL
A little late to the party. Put outside unit on the opposite side of where your winter snow comes from.
Inside unit as far away from milling machines as possible. The cool will happen wherever you put it. Like a breeze? Get a fan.
Jackfre
N CA
IN the cooling mode, the air will blow above your head to settle into the space as cool air is heavier than warm air. You will be fine in cooling but in the heat mode the unit will blow air directly down onto the floor, say about 6’ out to the floor. Standing in front of it will heat you up and be uncomfortable.
Mister Ed
Funny this came back to the top today ... I just got it working last evening. I had to wait until the weather warmed a bit to pour a little concrete slab (not sure why I thought I needed to buy it in Feb, LOL). I then have some pretty cool rubber risers on the concrete to raise the outside unit 3". I cannot really hear it running from inside (on the opposite side of the wall). I positioned the indoor unit on a side wall, still blowing on work area, but further away from mill ... a bit of a compromise.
I am sure I will figure the most comfortable solution out. I can control the swing on the louvers up/down & side/side and can also play with fan speeds.
I will grab some pics and will have a chance to play around with it the next couple of days ... temps close to 90*.
Crowbarman55
Unfortunately my winter snow comes from all directions. West or South is not to bad. East or North, look out its lake effect snow and it's going to dump snow and drift.
Todd
Dig Doug
i don’t think it will matter where you mount the AC unit if it’s sized correctly.
Although, I would add a ceiling fan or 2 depending on your shop space size. They are reversible so they can pull up air or just blow air down.
With air movement you feel cooler during summer, and pull the hot air down during winter.
i can keep my garage about 78/ 80 when it’s 105 /110 and with my 3- 84inch metal fans it feels really cool. My neighbor says my garage feels a lot cooler than his. He doesn’t have ceiling fans!
Mister Ed
Ok here are some pics of the completed project.
Outside
A pic of the mounting pads I was referring to:
And the final location of the indoor unit (ignore the mess, hopefully back in order this week). I wanted to move that wooden cabinet and install the indoor unit further to the right ... but that would have been a monumental task and would have required a longer line set (as I mentioned a bit of a compromise). This unit will not be on 24x7, so I think I will learn to live with the location.
