Post building wet set anchors
bfarroo
Green Bay WI
I've been looking for info on wet set anchors for pole buildings for use with 3 2x6's laminated together. The quotes I got for buildings listed using this type of anchor but the grade beam for the floating slab spec'd by most places was 14inches thick or less. All of the wet set anchors I'm finding are 18inches long. When they set them do they cut them to length? Possibly bend an L in them? I like the idea of the wet set over the drilled in ones since they go all the way to the bottom of the grade beam and just seem like they would be stronger. What have you all used when putting your building on a floating slab.
