(Thanks to this forum and its community - much appreciated)
So ... a perma-column is basically a "post extension" and you could make a post extension in a lot of ways. A concrete post extension (perma-column or DIY with sonotube) or a steel beam post extension ... or even just another piece of wooden post. Just different ways of extending a post (since part of it was cut off for being rotten).
Three initial engineering questions come to mind:
First, *if* you properly connect a post extension (below) to an existing post (above) does it really become, effectively, one post ? I understand all of the lateral strength benefits that a sunken pole give to a pole barn (thanks to research on this forum) and so I start to worry that a post with a joint in it can provide those same benefits.
Second, shouldn't my post extension go as deep or even deeper than my existing poles ? That's difficult to do with perma-columns since they are only 5' long and 12-18" of them will be above ground anyway ... if you have poles buried 6' or deeper in the ground, don't you need a 7-8' perma-column ? Is there something about these engineered posts that would lessen your depth requirements for seismic and wind load ?
Third, would pouring concrete around a post extension defeat the purpose ? Let's say I use a perma-column and I dig out my hole 18" in diameter, attach the perma-column and then fill in the hole with concrete. That really appeals to me because it is so solid and I am effectively building a mini-pier under the column ... but maybe that would be a very bad idea because you would then lose all flex at ground level, since the perma-column would be totally immoveable, and you're basically turning your in-ground pole into a very expensive pier ... not only would you lose all the lateral benefits of the in-ground pole, but now you've got your bracket up at 12-18" high ... basically little stilts on top of piers.
Am I correct to be cautious about a pole-extension inside a pier like that ?
Thanks, as always.
Thanks, as always.
