Flu Season… I should have gotten a flu shot, hindsight is always 20/20.
Progress has been slow on anything resembling work, professionally or in the shop, due to a nasty case of the flu that has had me down for about a week. In-between shots of NyQuil, I did sneak into the shop to make a little headway on cleaning up the “new” Hobart Tigwave. After giving it a good cleaning, both inside and out, it was apparent that the sheet metal had grown some surface rust and needed a little attention.
Here is what I found once I pulled the sides…
After a little elbow grease (and a lot of rags)…
The base…
Cleaned…
Wire wheeled the rusty areas and primed…
Painted and the base back together…
I cleaned-up the front and rebuilt the gas valve while I was at it. Hobart doesn’t support this welder anymore but the company that made the valve is still going and the rebuild kit number was on the valve!
The rust on the panels wasn’t deep but there was a lot of it. After looking around on the Net for the gold color code I decided to go with stuff I already had on hand. The plan had been to build a cart for the Mig with drawers. For that build I had bought some Valspar Tractor Paint in white and orange plus a can of primer. I had a sign company make up two Hobart stencils (one was for the drawer and the other was a back-up). Since the Tig holds 2 full sized bottles and to save on shop space, I am now going to put the Mig set-up on top and don't need to build the cart leaving all these materials without a purpose. Why not use them up?
Stencil…
Orange patch on the primed side panel…
Stencil on…
On with the white… (It's hard to see the stencil after the white. I'm hoping once I pull the letters the orange looks good)
I’ll pull the stencil after the white has had time to dry a little. The enamel drys really slow, even with the added hardener so it may be a day or two before I can pull the letters and get it buttoned back up.
I’m hoping that I have time in the shop this weekend but my wife’s sister and boyfriend are coming into town so that may be a pipe dream. Oh well, it will be great to see Jen's sister. Last time she was here Jen was in the hospital and this is the first time we have met her boyfriend. Plus, more time for this stuff to cure.
Also, I found the Valspar primer shoots and sands really well so I think I will be using it moving forward on the mill.
Thanks for checking in. As always, I appreciate it. Have a great weekend everyone!
Cheers,
Chris
OK. I got anxious to see how it looked and pulled the stencil before making dinner.
The base…
Cleaned…
Stencil…
Stencil on…
Cheers,
Chris
Not sure where that comes from.
Does anyone else really dislike the smell of gear oil?
