earl84
Ok, not real mainstream heating and AC question. I have a poultry water heater base to keep it from freezing, the heating element burned out. I cannot find a source for a replacement. Unfortunately I don’t have a picture of it. I sort of fixed it yesterday, but have limited confidence in the longevity of the repair. They’re not horribly expensive, but $50 is not inexpensive for such a simple thing.
They are very simple. 120volt to a thermal switch to the 110 watt foil heating elemen, which is just wire sandwiched between two foil sheets and stuck to bottom of galvanized base. I know the thermal switch works, stuck it in freezer and then tested for continuity. Also, repaired heating element burned up spots, then held snow against the switch, and the heating element got hot.
This is the heater.
This is the heater.
