I need to pour a concrete distribution box for my irrigation ditch. There are already plastic pipes in place for the feed and main run so a premade box will not work. I dug out an approximately 3'x3' square between the pipes and now I just need to pour the concrete.
Which of these options would be the best approach?
1. Pour the walls first and then pour a floor after removing the inside forms.
2. Pour the floor first and then pour the walls.
3. Try to pour the floor and walls at the same time with some sort of floating form for the center.
4. Something completely different.
I assume that if I did 1 or 2 there would be some leakage between the floors and walls.
