jaysonb
If I was to have an old tool box blasted and powder coated, and there were dents in the box that you couldn't hammer out because of the box being double wall, is there a filler that powder coat will work with?
jb weld will melt down at 350 in an oven..... I use a product called all metal for parts that have a lot of corrosion. After using the all metal I sand smooth put a thick primer coat on of powder then apply top coat and clear coatgood luck
respectfully have to say yer' speakin incorrect data, I do a lot of custom tins and they always need small ding and dent repair, in other words, I use it a lot and prefer its workability over lab metal in a can.
Never tried the JB weld is it that much easier to work with than lab metal. I do this on the side to enable my tool addiction Seriously how easy is the Jb weld to work with. I have a customer bringing me a tool box he wants me to do.
JB Weld will not melt down at 350F . It is used all the time in powder coating, where cure temps are 400f, as a cheap alternative to welding the dings. I use a product from tiger-Drylac called EpoStrong. Its an epoxy filler made specifically for powder coating and works just like bondo but wont shrink and pop in the oven like standard bondo. All Metal works but is very expensive for the ammount you get and canwithstand 350F but can go to 420 for a max 20 minutes to powdercoat. Hi Temp Lab Metal is for multiple heat cycles and can withstand 1000F and works well also but again very expensive for the amount you get.The downside to the HighTemp Lab Metal is that it needs to be applied and then air dry for 24 hours before an oven cure for an hour before you can work it.
Epo strong is this less expensive than lab metal and how big is the container. I am used to using lab metal but might try epo strong or jb weld just to see the difference thanks for any info you might have.
Th EpoStrong runs about $70, but you get a 2lb can of putty and a 1lb can of hardener. So it goes a long way. If you need filler often it is the way to go. I used a lot of it converting these rare mercury valve covers:
Hey Marc!
