I have had a couple sets of steel wheels powdercoated years ago and they held up fine (used them on my Jeep) but having been a front end alignment guy, I remember particularly on the Ford trucks of the early-mid 90s which are known to have issues with shackles and front spring brackets rusting out, they had a coating of some kind on them; and this coating would peel in strips, and be rusty/bubbly underneath. This coating was meant to protect the metal. but it seemed to "speed up" the deterioration instead. I am wondering if this was powdercoat; if so, what I have heard about "no chemical bond" may be true. They rotted out faster than the older versions of these trucks which had no coating at all, just bare steel. I always wondered what this "paint" was, that they had used on them.
At least bare steel is exposed, so it can dry; you get moisture under a coating, it don't dry out as fast and accelerates rusting
another option; it's possible they didnt prep the surface right, each step added to such a major production line adds cost.
At present, I am redoing a 2 post Weaver lift before I put it up. I was just gonna put it up, in as-bought condition, figuring that it wouldn't stay that "pretty" for long anyway, and "pretty" don't make a lift work any better.
but being that my son happens to be the "sandblaster/powdercoat guy" at his job, he convinced me to let him take it to work and powdercoat it, before I put it up in my garage...
my concern is mostly in the base plate of the columns, and the floor plate that goes between the columns, where it can't be seen>> but will be in constant contact with concrete on the bottom. IDK what finish Weaver would have been using in 1986, but even the top side of the base plate, and a few inches up the column is peeled and surface rusted; understandable for a 27 yo piece of industrial machinery; but the coating (paint?) is fine, held up good, beyond that lower most few inches off the ground. (the floor plate has been brush painted at least once though, the columns haven't been).
I don't want what is in contact with the ground to rot out from beneath.
it isn't peeling in the same way those Ford truck spring brackets did, so I think it was some kind of "paint" and not a powdercoat type substance used originally on this lift. it "flakes" off, like a "paint" would, when scraped with a razor blade.. not coming off in long strips like those suspension brackets would
Yes we are sandblasting and coating the entire column not just the flaky/ peely parts...
my neighbor that works at Valspar suggested that if I wanted, he could get me some baked on enamel that we could paint the lift with rather than PC it, (not "free" but cheaper than Rustoleum bought at retail, so he says) and being my son is currently doing PC, we obviously have access to an oven to do the baking, if we went that route.. which would hold up better?
consider the environment, (home garage not a production shop-- rack use probably 2-3 times a week, not multiple times a day like a production shop) sweating concrete, no airflow between the concrete and bottom of the column bases and floorplate) auto fluids that could be spilled on the lift at any time (brake fluid, oil, gas, antifreeze) tools being dropped, the lift arms being kicked and possibly run into by my riding mower, and such ("likeliness to chip" factor), the lift pads being scraped against a car's lift points and such.
I will have dry heat in before next winter, some of my moisture issue is the kerosene "torpedo" heater I have been using out there to date/by next winter I will have my hanging NG Modine heater connected and working.
I know every piece of equip and environment is different...
in this case the cost will be less than "retail" which ever way I go, so cost isn't as much a factor as it would/could be...
