Power Caster
Steevo
43.49600, -112.04300
What is your intended use for it?
I read the specs on the web site and I think the idea of using the tongue jack to push/pull the trailer around is a bad idea. Seems like a good way to bend your jack, or strain the mount, especially with a loaded trailer.
I think I'd weld a plate under the tongue just behind the hitch somewhere, with a socket for the power caster to fit into.
Have you looked through what is available at Surplus Center for a motor?
https://www.surpluscenter.com/home.asp?UID=2009062709354063
kbs2244
The scooter motor should work fine.
To ease steevo’s fear I have seen them used with little post that fits on that stub with a trailer ball on top.
It fits into the normal ball hole on the tongue.
Dustball
Hudson, WI
I agree that using the trailer jack to move the trailer around isn't a good idea but they do sell brackets that bolt directly to the tongue. I'd go that route.
