Nortonscustom
- Joined
- Jun 5, 2008
- Messages
- 375
While back saw a post about a power drawbar made from a butterfly impact wrench. Can't find the thread now but figured I'd post a few pictures of the butterfly impact based drawbar I built.
Goal was to try to make it entirely out of parts and material I already had and to get some practice on the new mill. Still ended up having to buy a few fittings but that's just how projects go.
Started by making the base plate and support for the impact wrench. Used bronze flange bushings in the support.
Next made the control valve body and switch lever. The valve body also doubles as a manifold. The two straight ports get one way check valves and will feed the cylinder. The angled ports feed the air motor.
Added a couple steel buttons to the switch lever to contact with the steel pins of the control valve.
Here's a picture of the inner workings on the control valve. You need to add an exhaust port to the valve in order to make it remote.
Here's all the bits ready for assembly. Added a mini inline oiler to the control valve to keep things lubed. The little hex shaped manifold on the air cylinder was actually a high school shop class project. It's been sitting in the top shelf of my toolbox for 20 plus years. Knew I would use it some day! Out of the top of that manifold is an exhaust flow control valve. It releases the air trapped by the check valves and controls the retract speed of the cylinder.
Here's the gizmo assembled and ready to go. It works like a champ and was a fun project.
