Innovate1
Had a storm come through last night and lost power about 4:30 PM. Had some hail - nothing too large in my area and some wind and moderately heavy rain. Was surprised that was enough to knock out power. It was out for about 3000 customers for about 4 hours. So I cranked up the generator. Dinner had just started cooking in the gas oven. Burners work without power but not the oven. With the generator the oven worked. Have two 200A panels with generator interlock on one - Microwave isn't on that panel - may have to change that. Was able to have the generator in the OHD opening with the exhaust pointed out so kept the generator out of the rain. And most storms come from the other direction so not much issue with rain blowing in with the door open. Ran for a couple hours and generator started running rougher and rougher until I shut it down. Power came on shortly after. Found some water in the float bowl. I typically run on plain gas with ethanol for any extended periods and run a bit of ethanol free through it when storing - that seemed to work well as it had been sitting for quite a while and fired right up. How to deal with water? I know some equipment has a filter bowl with a drain to catch water (and other crud). Airplane preflight is to drain a small amount from the low point of the tanks into a transparent tube so any water can be seen. There's a small in line filter but it doesn't stop water.
