Power Probe 4 --- Just announced!
woodstockva
USA
Looks like we now know why all the Power Probe 3's dropped in price a couple months ago.....this one looks like quite the upgrade!
<iframe width="560" height="315" src="//www.youtube.com/embed/krAUIq3bWIg" frameborder="0" allowfullscreen></iframe>
fordbroncodave
good thing its coming because our pp 3 is almost done for.
I hope the sound speaker actually works and keeps working. We had sent ours in several times from speaker failure
signcrafter
Waiting to see what they want for this one. I like the AC meter and the pulse width features. But I don't think it will be worth upgrading my PP3 if it's over 150 bucks.
KinzeMech
Meh.
I have a PP3. I like it, but I don't think I have it out of it's case more often than once a month.
dclassical
Good timing!! I was about to order the PP3 combo from Amazon! I think I will wait and check the price on this one.
justme-
Boston suburbs
Was just talking to a tech that has a Hook - he couldn't say enough good about it - 15 minutes telling me what it can do and how to use it. This had better be a significant upgrade to the PP3 (which I have) or it's not worth it.
brass89
I forgot how old the pp3 is. Couldn't remember which one I'd picked up, the 2 or 3.. searched for them and popped open the amazon link, good thing they remembered. Apparently I got the pp3 back in 2009. At least I got it for a decent price, the current amazon sale is for $98 and I picked mine up for $100. It looks like the pp4 has to be brand new, I didn't even see it on the website. Looks like it has a couple new features and 3ft longer cables. Curious to see what the price is on them when they come out.
signcrafter
Never had a power probe and never needed one or wanted one,but now I want :drool:
I am with you on this one. Never bought it before but might get it now.
The PP3 is sure useful in certain situations. It doesn't do anything you can't do with a fluke and a set up homemade jumper wires to send power to things but it's a nice package. I don't use mine often, usually grab my fluke but the PP3 does come in handy.
The PP4 looks to have some added features like faster dc volt readings, AC RMS readings, pretty neat injector testing mode that shows the injector open time among other things, pulse width, and other things. I'm just waiting to see the price. If it's anywhere near the price of the hook I'm not interested.
komobu
Newport News Virginia
Meh.
My PP3 is my GoTo meter over my Fluke and my Verus Scope. Once you hook up the leads to the battery, there is no more having to move test leads. It also fits in tight areas where it may be hard to view a meter and hold the leads in place. Now that it has ohms capabilities, I will buy one as soon as I can and put my PP3 up for sale, but I just may keep it because I have been in rare situations where I could have used a second PP. It doesnt happen often, but it has happened like if I am working on an electrical issue with a helper and get called to a different vehicle for a quick fuse check. BTW, the PP3 works great for fuse checking!
The Wizard
Son of a gun! I just bought PP3 last week. Used it already and like it a lot.
If someone has the PP3 and the Hook, is there any reason to get this PPIV?
It seems the PPIV took a few (not all) of the Hook's features, all of the existing PP3 features and functions, added a bigger screen, and made it menu driven. Sound about right?
larryq
Not to hijack but does anyone have good links on how to use the PP3? I bought one and the videos that were on the enclosed CD-DVD were about two minutes each and were a little lacking, at least I thought?
komobu
What are you wanting to do? I could try to talk you through it. The beauty of the tool is its simple interface and no learning curve.
Basically, once you hook up the clamps to the battery, any wire you touch you will know if it has voltage on it or if it is grounded. You will need to have a basic understanding of circuit design more than anything. If you see the tip light up red, but only 5 volts for example, you know that a 5 volt reference line and dont give it 12v from the tip.
There are a bunch of videos on the PP3 on Youtube. Just do a search from there.
Ruger_556
Not to be the one to say this but a meter tells you exactly the same thing... I think it's kind of a solution looking for a problem myself. I can see it being handy to power components but rummaging for my jumper wires every once in a while isn't the end of the world. You guys do a lot of bench testing or? :headscrat Very rarely do I want outside power to a component, in vehicle hooked up to the harness tells me all I need to know usually with a backprobe, breakout harness, etc... :dunno:
Might be one of those things you have to use to appreciate?
toolslut6.0
Just talked to my cornwell guy. Says he has one on order and they are going to run around 200 bucks. I told him to tell me what he thinks of it.
komobu
Not to be the one to say this but a meter tells you exactly the same thing...... :dunno:
Absolutely...A meter tells you the same thing. A PP3 is also a meter where the PP1 and PP2 were not.
Do you work as a professional tech? If you do, and perform a lot of electrical as I do, I think you would find it a very convenient tool to have that allows you to diagnose electrical issues faster than a meter.
I have a Fluke meter that gets very little use in most automotive electrical issues I encounter. The meter is about the size of a brick but never seems to stay where you put it. So if you connect your test leads, it can be difficult to see the meter reading while balancing the meter on the air cleaner, fender well or radiator core support. Then the display can be difficult to see once you have your leads set. Now try viewing a meter when you are under a dash or inside a trunk, or inside a glove box, or a door panel.
The PP3 is much easier and that is why it is my goto tool for all electrical issues. After my initial assessment I may reach for my meter or even my scope, but first I goto my PP3.
Another thing about the power probe 3 is it kind of depends where most of your issues arise. I live in Virginia where rust and corrosion is not a big issue. As a result, most everything I experience is a component failure. I very rarely see a wiring issue. The PP3 lets me give power and grounds to verify the component very quickly. If I lived in the rust belt, I would probably experience more wire related issues than component failure. In which case I would use my Load Pro test leads by Dan Sullivan.
As I understand it, the new PP4 will be able to check resistance, and also the wiring all the way back to the battery. So I cant say for certain since I havent tried it yet, but it may eliminate the need for my Load Pro test leads.
Ruger_556
Yeah, Navistar/Kenworth dealer... I tend to get a lot of the electrical diag work because I can find wiring problems faster than most. I can see the usefulness for component failure though I suppose.
gte718p
That is cool, but I still think a good meter is a better investment. .1 volt resolution ***** when working with signals and resolution != accuracy. The PP1 and PP2 were stupid easy to build yourself with 5 dollars in components. I have never actually seen a III to know what it can to. Feeding components is useful, but again can be done with an alligator clip and a probe for about $.50 $20 bucks and you could generate any signal you want. I see the market from it as not everyone understands electricity nor wants to build their own tools, but as simple as it is I can't understand the price.
komobu
That explains it....As big and long as the trucks are your cord would have to be double. Not sure I would want one either to work on trucks but they are great for automotive. Check out Dan Sullivans Load Pro. He is a Truck Tech and designed them for working on trucks. You will probably like them:
